C500 color lines front to rear
  • racefreak
    • Sep 2010
    • 30
    [CQ] C500 color lines front to rear
    OK guys, I hope you can help. I've got a C500 with Cyan, Magenta and Black lines (no Yellow) running from front to rear on all paper. PM was just done 3k ago with new drum units, developer, dev units, Charge units and today I just replaced the entire transfer belt ass'y. The image is visible on the belt when stopping mid run and the image repeats every 190mm. The line itself is very faint and about 6mm wide running from front to rear thru the erase areas. It looks like a roller mark when a fuser roller is flat spot but again, it shows on the transfer belt pre-fuser.
    Any ideas would be greatly appreciated.
  • mrwho
    Major Asshole!
    • 4299
    If you could scan and post some examples it'd be easier to understand your problem.
    I'd guess you got lines on all colours - you probably say "no yellow" because thin yellow lines on white paper are hard to spot (one way of being sure would be to try some dark coloured paper to check if there are indeed yellow lines or not).
    Does it happen on copies and prints? Only copies? Only prints?
    Check if the time, date and serial numbers are input onto the machine. Check the controller connection to the machine.
    These are only best-guesses, as I said a scan of the problem would help.
    Mascan42
    Ibid
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      It could very well be the PRCB has failed in some way or another.
      But I agree with mrwho, a scanned image of the problem would best explain what you are seeing.
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
