Is the lower pressure roller from di750 compatible with di850
  • rlr42173
    • Mar 2007
    • 28
    [CQ] Is the lower pressure roller from di750 compatible with di850
    I have two Konica di850's or dl850's (Imagistics version). I have lots of toner chunks building up on the lower pressure roller, just wondering if the di750's roller is indeed compatible with the di850, cause it sure seems like it isn't. I get a buildup on the sponge roller, auxiliary roller, and the lower pressure roller itself.
    I can pick the toner chunks off easily if the copies are not double sided. I have worked on these two machines for 5-6 years now and never had a problem like this. To me it seems like the machine has a lot of extra melted toner in the fuser and that is what causes the problems, but I don't know. I am very frustrated with this. The main reason it is hard to figure out is because at the same time i changed the rollers, I also changed to a new batch of toner. Could it be the toner! Help!!!!!!!!!
