C3451 will not reset
  • josephc
    • May 2025
    [Error Code] C3451 will not reset
    c3451 error code ---Changed fuser unit ---tried hard reset/utility key + power sw. trouble reset comes up on screen but will not respond to touch.
    checked cables from mfpb to fuser unit -ok --voltages at pwb all checkout. any help ideas would be greatly appreciated
  • JustManuals
    • Jan 2006
    • 9838
    Re: C3451 will not reset
    Paul@justmanuals.com
    • rasman67
      Check the touch screen it could be bad.
      • josephc
        Thanks, any work around for checking the touchscreen(to confirm death) as i have no replacement,----when I try the hard reset---utilility+powerswitch It goes to the trouble reset on screen from there if I hit 0-0-s-0-0-1 to enter service it will flash to the service screen for a split second then return to error screen reporting C3451, checked right side switches and there is 120v to fuser power section on power supply board but nothing out to fuser -- it seem that the Mfpb is not sending any Signal to thyristors in fuser power section of board replaced mfpb still no joy don'nt want to go down the rabbit hole of blind Part replacemnt. Any thoughts would be greatly appreciated.
        • josephc
          Re: C3451 will not reset STATUS UPDATE
          after "rasman's" suggestion and a correspondence with "solotime" Got me thinking------(sometimes a dangerous proposition) ohmed out the four conductor ribbon to the touchscreen figuring that the resistance should change as the screen was touched---found open across 3 conductors -------reheated connection at glass--fired up and now trouble reset is functioning.
          Thanks fellas for pointing me in the right direction-----all the best!
            • 22939
            Did you mention what the model number was?
            I just can't seem to muster my psychic powers today. =^..^=
            • josephc
              sorry bizhub 352
              • josephc
                bizhub c352
                • josephc
                  Sorry c352
