I have a c 252 that has email issues, i place 5 pages in adf and it sends 5 1 page emails, i checked and the hdd was unplugged, the previous tech said it had a bad hdd, i want to replace the hdd and i need to know how to initalize the hdd when i replace it, can someone help.
Hdd install and initialize
erb
Re: Hdd install and initialize
thanks for the info, can you email me the proceedure for that, im not real familiar with konica minoltas.Comment
Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
erb
i did buy the service manuel on line, can you please direct me to the location in the service manuels (there are 2) on the previously stated directions on installing a new hdd.
THANK YOUComment
You dont need a hard drive to e mail scan , set the document type in scan to mustiple page pdf and it will scan as many as the it allow.Comment
erb
I couldnt find a screen in the machine to change the setting to multi page originalsComment
erb
i still couldnt find an option for single/multi pages any place in any screen, i did install the hdd, set machine in service mode to hdd, then did physical format, then logical format, when i did the logical ithe op panel went blank and wouldnt return, i waited 10 min and still no op panel. is this normal, i left the machine in the logical format running last night in hopes it would finish and have the machine reset this am by another tech. can i get some please get some help on this.Comment
why dont you just read the manual.....thats the reason for getting it......next you'll be asking someone to wipe your backside for you.....Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
erb
Join DateSep 2011Locationphoenix azPosts7 Rep Power0
thanksmaybe you can help me with my backside with your tounge
thanks again for all your help
is this the sort of private messages you like to send.......if you read the manual...instead of getting a manual & asking where you should read...maybe i might help!!!Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
