I've got a IC-413 (Fiery E100 70-60C-KM) connected to a C6000 with about 63000 prints on it. The machine control panel initially displays a message that the "controller is not connected" and the LED on the fiery displays AA after starting up. I have replaced HDD and RAM but when i follow the service manual exactly and install system software via USB or LAN I get 02 on the LED display and it stays like that for more than an hour. Next step is to replace the mobo, has anyone seen and resolved this issue? Also, is there a list or chart depicting what the LED codes actually mean? I did a forum search for IC-413, the panel message, and the LED codes and got nothing, thanks in advance.
AA=dead fiery?
Re: AA=dead fiery?
.....You must reimput the system software in the IC..Comment
d.v.ramanababu
Re: AA=dead fiery?
it will repeated after some days what is the permanent solution for AA problem in IC413 Fiery controller.i updated patches and re install software too.Comment
lnkumaar
Re: AA=dead fiery?
i think, the problem was due to lack of proper shut down.
i hope u r shutting down controller, properly.
if not, try it.
go to controller on the control panel of the machine
and den
SHUTDOWN FIERY
den switch off sub power and den main power.Comment
Re: AA=dead fiery?
I've got a IC-413 (Fiery E100 70-60C-KM) connected to a C6000 with about 63000 prints on it. The machine control panel initially displays a message that the "controller is not connected" and the LED on the fiery displays AA after starting up. I have replaced HDD and RAM but when i follow the service manual exactly and install system software via USB or LAN I get 02 on the LED display and it stays like that for more than an hour. Next step is to replace the mobo, has anyone seen and resolved this issue? Also, is there a list or chart depicting what the LED codes actually mean? I did a forum search for IC-413, the panel message, and the LED codes and got nothing, thanks in advance.).
I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.Comment
Re: AA=dead fiery?
I just had this problem pop up today. I tried to reload system software from the disk that came with the fiery but i get a vbs script error right away. I also tried to load it to a thumb drive useing the USB utilite but it goes from 30 min to several hours then gives an error. I am pretty sure it is a bad file on the disk. Has any one else seen this with the disks that come with it? I ordered a new cd from Kmbs but it's on back order till the end of the month. Does any one know if I could get it directly from EFI? Thanks in advance.Comment
Re: AA=dead fiery?
I have discovered that the problem loading the system software was with my laptop not the disk. In my case the AA is probably not a bad HDD because I can remote into the Fiery and windows has booted but the Fiery software is not loading. It had a message about a corrupt file.Comment
iduno2much
Re: AA=dead fiery?
There are 2 Fiery patches that can help with AA codes. Install them after you get it up and running.Comment
