bizhub 420 regarding OACB and counter
  • enygma
    • Aug 2009
    • 17
    Hello,
    I have just replaced a new Overall Control Board on bizhub 420. My problem now is that the counter (from the board) is not match to the mechanical counter. Is there a way that i could synchronize the counters? Thank you.
    • 23008
    Re: bizhub 420 regarding OACB and counter
    I just called the hotline last Friday on that exact question for the bizhub 423. The answer was "No. The count restarts at zero. Period."
    The serial number re-entry was easy enough. Did you figure out how to do the license management repair? I'm still working on that part. =^..^=
    • enygma
      • Aug 2009
      • 17
      Thank you for the reply. About the license management repair, i have not yet encounter it.
        • 23008
        I'm not exactly sure what license disappears, but it's lost when the NVRAM is removed from the original board.
        Two hours on hold for 2 minutes of advice. =^..^=
        • Albonline
          • Sep 2008
          • 1151
          you need to print out the licence renew request number, then log on to konicas licence management server ,input the request number ,it will give you a number to input to the mfp, and the error will be cleared
            • 23008
            Yeah. I've got the report. I just need to do the part on the server. =^..^=
