Bizhub 654 jam 66-14
  • sauce_boss
    • Oct 2011
    • 26
    Have a new machine has been getting this code since it was installed. Page goes through makes the copy but then indicates j66-14 after. Lift the lid and lower it and it clears. It's an exit jam. exit sensor checks out ok in I/O mode swapped it anyway with no luck. Before read sensor checks out in I/O mode. Exit motor is obviously working. Called Konica and they suggested replacing the df control board, that has been done with no change. Also re-seated all connectors from df to main body. Anyone seen this or have an idea of where to look next?
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub 654 jam 66-14
    There is a bank of 3 sensors located under the jam access cover towards the front of the MFP. We started seeing jams caused by these sensors getting stuck in the access cover cutouts. Install a piece of mylar that tends to push the sensors down about 1mm or so. Emujo
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
        • 22946
        I think I understand ... but what is "flaffed"?
        I think I might be flaffed right now ... =^..^=
