Need to format the HDD on a Konica Minolta C552
  • copyman20
    • 207
    I need to format the HDD on 2 of these machines at a doctor's office. have not worked on these very often. can someone give me some step by step instruction on how to get this done?
    Thank you in advance.
  • street951
    Re: Need to format the HDD on a Konica Minolta C552
    in system1 or system2 tab should come the HDD FORMAT option or something
    • copyman20
      • 207
      Thanks for the link.
      • copier tech
        • 8105
        I have a customer that after we removed their C552 & C353 machines they wanted the HDDs removed, so I stripped them out & gave them to the customer, so all good.But now I have the machines with missing hard drives, if I simply fit new drives what do I need to do, eg do I need to reload firmware etc? Any advice would be appreciated.
        • TheOwl
          • Nov 2008
          • 1732
          Probably should have started another thread for this one... But anyway.
          The HDD's in Konica Minolta devices (as well as pretty much any other device) are simply just an off the shelf HDD. Make sure that when you get an HDD to replace the missing drives, you get a drive that is the same size or larger.
          Once the HDD is fitted, do a Logical Format from service mode and then you are done on the C353. On the C552, you will then also need to load on the animation data from a USB drive and using "Install" in System 1 or 2.
          • AlSyed
            NewBee
            • Aug 2010
            • 41
            "The HDD's in Konica Minolta devices (as well as pretty much any other device) are simply just an off the shelf HDD."
            Sorry for my ignorance but recent models do not take the regular 3.5 HDD, The new ones take some special ones as I understand.
            Larger sizes tends to give problem but same or almost the same sizes works.
            Please share if you have any detail about the type of HDD for newer copiers.
            Sincere Regards for your kind help.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4542
              If I'm not mistaken with new HDD you will need to do the physical format first (can take hours), then do the logical format after
              • femaster
                • May 2011
                • 1466
                This thread is over 6 years old, which is why the information you are quoting seems outdated. It's probably best you start a new thread that would apply to more modern models. I'm sure will get far more responses about modern drives with a subject that doesn't have C552 in it.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4542
                  My reply was for more recent Konica Minolta models as well. I've even had to do physical formats first when swapping from one "4" series to another.
                  • femaster
                    • May 2011
                    • 1466
                    I was just letting the other poster know it was an old thread, and they would probably get better advice if they started a new thread with a subject pertaining to newer hardware.
                    Nothing against you. Your advice was sound, which is why I didn't quote your post. I've experienced the same thing with "4" and "4e" as well. With the more modern copiers I've gotten to the point where, if I'm not at a customer's site, I just do the physical to start with.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4542
                      No offence taken. I only quoted you so other members didn't think it was just for older models only (which come to think of it even the 4 series is getting old)
                      Ouch! With doing physical format in customers office. I've had it take hours to do physical format. How do you do it? Do you stop back later in day? What if the customer is not under contract, how do you bill them for that. Hope I never have to do it but just in case. Fortunately only had to do in shop.
                      Added after: I misread the post and see you said when NOT in customers office. Oh well perhaps my post will still help someone to know it takes hours and may want to try just the logical format first!
                      • tsbservice
                        Field tech
                        • 7924
                        I think what femaster means is to do physical formats only on devices in service shop, not at client sites, basically same as you do.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4542
                          By the way do you think anything I post is helpful and you like?
                          • femaster
                            • May 2011
                            • 1466
                            Yes, you are both correct, that is what I meant and I probably could have been a little more clear with what I typed. When in customer's office, I always try logical first. Physical is definitely not something you want to do on-site unless absolutely necessary. As you said copyman, a physical format can take many hours to complete and leaves the customers machine down for extended periods of times. It's definitely not a desirable situation for the customer or us.
                            • tsbservice
                              Field tech
                              • 7924
                              Yes of course. I really have them all if you mean bulletins.
