Imagistics IM2520/Konica MinoltaDI 2510
  • Jerry
    • May 2025
    Have not seen problem in person, another tech called me and asked to post. Display has lines 1/16\" wide running horizonal and vertical. You can barely read the wait warming up and when ready you can\'t see anything. It will not copy, everything is locked up. He has replaced the complete opp panel from a good working machine, same problem. The hot line had him change the main board, same problem. He also unhooked all options, same problem. Anyone seen this befor? Thanks guys for any help.
  • 10871087
    • Jan 2005
    • 1143
    Re:Imagistics IM2520/Konica Minolta DI2510
    Seen something like it on a Kyocera machine a few years ago. It ended up being a pinched wire. I would look closely at the wiring from the op unit back to the Main PCB.
    • Jerry
      Found problem, the controller board that sits on top of the MFB was bad.
