Copier Porn
  • Madnhain
    • Dec 2012
    • 148
    Copier Porn
    We were talking about copier porn today. You know... pictures of copiers with their covers off. We couldn't find anything good unfortunately, So.... lay it on me! What's your best copier porn?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Copier Porn
    http://www.copytechnet.com/forums/at...es-branden-jpg
    Well, here is one machine that's all burnt out (thanks to another member).
    • austonrush
      Sharp & HP Tech
      • 234
      Re: Copier Porn
      Can anyone tell what brand of copier that actually is?! Isn't she sexy, lol!
        • 23009
        Re: Copier Porn
        Do cats count? In all my cat pictures, the cats are naked. This is Honey. See? No clothes. She hates clothes.:
        The rest of these are fairly random photos:
        Yes. One tech can remove the imaging drawer from a PRO1052.
        How do you keep staple trimmings from shorting out your FS-532 finisher controller? Use really big refrigerator magnets:
        How does a KM-8000i look when you've replaced every individual part of the bridge unit? Be sure to include the exit sensor. You know, the part it actually needed:
        • TheBlueOrleans
          • Aug 2012
          • 232
          Re: Copier Porn
          I wouldn't mind seeing the KM-1 sans covers.
          But I like 'em like that.
          Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
          • Madnhain
            • Dec 2012
            • 148
            Re: Copier Porn
            Looks like it might be an old Sharp AR-M355 or something similar
            • habik
              • 2013
              Re: Copier Porn
              How about some sexy trim on a UFR.
              Each time I wink at her she winks back, love her eye colour.
              Is she inviting?
              Don't like her biting though.
              Firmwares HERE
              • subaro
                • Oct 2010
                • 1274
                Re: Copier Porn
                The first one a memory expansion card from back in times when you had to add memory to your computer. This card held about 4mb.
                The sesond is the underneath of a lexmark xm3150 that i worked on today to replace the input sensor. Anyone going to do this, well let me just put it this way. This is the most absurd repair description i have ever had to do. look in the service manual and see and it is not easy. I did it another way, cut and solder, but you still have to remove parts, that you have to have dexterity to put back.
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: Copier Porn
                  It isn't a copier, but it might still work.
                  • ZOOTECH
                    • 3375
                    Re: Copier Porn
                    Originally posted by subaro
                    [ATTACH=CONFIG]33666[/ATTACH][ATTACH=CONFIG]33667[/ATTACH]
                    I feel for you; Lexmark will have 5-15 links in their manual to remove parts/covers to get to one sensor, motor, etc to replace one simple part.
                      • 23009
                      Re: Copier Porn
                      I've changed a few of those paper pickup units on the larger Lexies.
                      What a treat!? First I have to find somebody capable of helping me lift the engine off the base. Then remove consumables and cassettes, and tip over the engine on it's back. Of course there's not 4mm of extra wire to release the harness from the looms. =^..^=
                      • subaro
                        • Oct 2010
                        • 1274
                        Re: Copier Porn
                        and cut the cable near the frame to detach the sensors.
                        9 Remove the other half of the cable from the printer
                        Installation notes:
                        a Install the duplex sensor, followed by the input sensor.
                        b Route the cable using the new path.
                        c Secure the cable near the lift plate gearbox using cable ties. Cut off any excess cable tie.
                        • ZOOTECH
                          • 3375
                          Re: Copier Porn
                          Installation notes:
                          Yeah, that's how I remember it - an absolute FUBAR.
                          • Lagonda
                            • Aug 2008
                            • 1649
                            Re: Copier Porn
                            [ATTACH=CONFIG]33653[/ATTACH]
                            You get your jollies from pictures of Savin copyprinters?? You need some serious help Blackcat!!!!
                            • allan
                              RTFM!!
                              • 5462
                              Re: Copier Porn
                              with Riso's we would still understand.
                              Whatever
