Have some fun...Been in this biz so long....
  • copyman
    Owner / Technician
    • Sep 2005
    • 4520
    Feel free to add....
    Been in this business so long that I remember:
    Restringing Canon corona grids
    Replacing exposure lamps
    These were just a few that came to mind, there are plenty more....
  • allan
    RTFM!!
    • 5459
    Re: Have some fun...Been in this biz so long....
    Cleaning up silicone oil spills.
    Adjusting lamp/charge voltages with pots and real test charts...
    Whatever
    • jonhiker
      • 661
      going from paper manuals to cd's to downloading
        • 22927
        Not just a few ... a whole trunk load of manuals. =^..^=
        • tech28
          • Jun 2013
          • 434
          The manuals, wall full of them, ordering Canon manuals from a dealer in Texas for 150 a pop. Back in early 90's. To Intravia coming out with his genius idea, still have the whole set, get info from that once in a while. Now, everything is downloaded. Also, can't remember last time I had to replace a heater lamp, exposure/element scanning lamp/thermister. Oh, how times have changed. So much easier, less time consuming, cleaner hands! LOL! But, the pants still get all messed up in the knee area, can's get away from that.,
          • Etech50
            • Oct 2017
            • 27
            As far as the scan lamps being a thing of the past, we used to have a crush proof tube to hold all the different lamps, got rid of that long ago.
            Also, as to physical books, we had parts manuals on microfishe with a small reader that never seems to work.
            I will add drive chains to the list, last one I remember was the Canon NP6650.
            Even older than using VR's to adjust timing was physically moving the scanner sensors to adjust registration.
            My brain seems to remember not even getting jams codes when I first started, just the flashing jam light.
            As far as software goes, I recall changing EEPROM's on NP6551's, taking 30 minutes to flash an IR600 via parallel if you were lucky to remember the DOS commands. Now, plug in your USB key or download direct via the web.
            • Grey
              • 38
              Fun times in 1976 with heavy paper rolls, cutter knives, cherry switch failures x hundreds, relay boards and big ass cam assemblies for timing functions.
              Toner tanks filled with liquid stinking ink that gave you weak ass copy quality for about 5,000 clicks.
              You had better commit to memory every component in the machine to pass the Saxon Factory Cerification.
              Oh to be young!
              Grey
              • Lagonda
                • Aug 2008
                • 1649
                Doctor gap gauges...........
                Using a drum shoe to set corona charge currents......
                Draining the sump on wet copiers to replace them with these new fangled dry powder ones.
                When the only thing a photocopier did was make photocopies......
                • Grey
                  • 38
                  Ok, how could I have forgotten this one!
                  Wax temp sticks to test the fuser adjustment for drying the wet paper as it passes over the 'hot plate'.
                  And having 60 or so damn fuses on you at all calls with your multimeter at the ready
                  Grey
                  • Lagonda
                    • Aug 2008
                    • 1649
                    Originally posted by Grey
                    ...........Wax temp sticks to test the fuser adjustment for drying the wet paper as it passes over the 'hot plate"................
                    Geez,you have been in this game a long while, I've never heard of that one before!
                      • 36745
                      Clearing squeegee roller jams on an Apeco Super Stat II
                      • BaconSteve
                        • Apr 2019
                        • 140
                          CHAIN DRIVEN main components on copiers
                          Mimeograph hand driven printers that used the ink that SMELLED sooo good to the students..
                          B&W only printers
                          before them... IMPACT Printer
                          EDLIN
                          yeah I rode a stone-wheel cart to go to school... but ONLY when the snow was less that 8" deep
                          and all of the other comments made!
                            mailing systems that could only perform 1 function at a time.. weigh - stamp - seal.... taking 3 runs of the envelopes
                            never mind mail-merge with a six tray insert/fold/weigh/stamp/seal in one contiguous process
                            • Zeldaman
                              • Mar 2011
                              • 946
