ADMIN HELP can't log on with win xp
  • copyman
    Owner / Technician
    • Sep 2005
    • 4738
    Hi,
    I can't get on this site from my shop PC which is XP. Tried the HTTPs\\:, etc stuff suggested on home page. get the message "This site cant be reached"
    Any suggestions? If you are wondering why not just use another PC. Well my shop (right next to house) is where my peace & quiet is at night. Will still use the site but not that often (I'm sure there are some that are OK with that)
    Thanks for any suggestions
    • 23010
    Re: ADMIN HELP can't log on with win xp
    Aneurysm has suggested clearing your cache. That helped just now, when I could log in, but did not redirect. For me it's still showing as http:// and not-secure logo. I'm assuming that will change at some point.
    • mikadonovan
      • May 2008
      • 2931
      6 months after security updates were stopped for XP, my computer was so screwed up I could not get anything to work right. Time for a OS update (Don't update to win 7, security updates cease in January). I have had good luck with Linux Mint (free, open source) installed on 2 of my computers.
      NEVER ASSUME ANYTHING
      • tsbservice
        Field tech
        • 8031
        Agree with mikadonovan, Linux distribution is the way you go when Hardware is from previous century.
        I had big book for Win XP which read from top to the bottom and still use learned but it's time now
        • copier tech
          • 8193
          Have you tried another browser? Chrome for example?
          โ€‹
          • qbert69
            • Mar 2013
            • 1152
            Yep. Linux Mint is the "go to", as they still post -32 & -64 bit distros, plus they have 3 different desktop environments!!![emoji41][emoji1303]
            Sent from my SM-N950U1 using Tapatalk
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
              • 37558
              In all likely hood if you are still using XP, odds are that your hardware is not supported by current Microsoft Windows OS. Your options are try Linux Mint or buy a new computer. Start saving up now because eventually a hardware failure is going to force you to buy a new computer.
              • qbert69
                • Mar 2013
                • 1152
                I'm not using XP...I'm using Windows 7 as I do some 3D printing and 7 is not bloated like 10 is with the extraneous eye candy & layers of crap. I have GWX Control Panel installed so a 10 upgrade doesn't "accidentally" get slipped in and f*ck up my whole setup. BTW, I have found BitDefender to be an excellent non invasive antivirus! Also, Emsisoft uses the BitDefender engine![emoji6][emoji1303]
                  • 37558
                  You're not the person who originated the thread. I quoted you since you were recommending Linux Mint or do you not like to have people agree with you?
                  • qbert69
                    • Mar 2013
                    • 1152
                    I was just vouching for the fact that Linux Mint is an excellent alternative if you have older hardware and don't want to upgrade & throw pearls after the Microsoft swine!!![emoji23] My Windows 7 angle was due the fact I rely on it for my 3D printing workflow!!! XP has been booted to the curb!!! I really never used XP & neither Vista. 7 was always the "happy medium" for me![emoji6]
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4738
                      I wasnโ€™t asking for advise about upgrading. I know XP is old, and from last century, etc etc... I have several computers ranging from XP (use in shop, mostly manuals) to win 10 on laptop. I was only asking to see if there was a way to keep using my old pc in shop. I pm'd aneurysm to see if anything can be done since it happen after the recent upgrade to site.
                      In meantime I found that firefox works with XP & 7 and no problems logging onto this site. Guess I'll be keeping XP for a little while longer
                      Love WinXP / Win7. Will keep as long as I can
                      Hate Win10 !!!
                      • qbert69
                        • Mar 2013
                        • 1152
                        I betcha Linux Mint 32 bit with the xfce windowing would run quite well on your hardware!!! ...and if not, you could try Linux Lite OS or even Puppy Linux!!![emoji23][emoji1303]...just save your files to an external HDD and load the "new" OS!!! You can make a multi-boot USB thumb drive with YUMI!!!... and you can actually try your booted distro before you install it!!!
                        YUMI โ€“ Multiboot USB Creator | USB Pen Drive Linux
                        Linux Distros:
                        DistroWatch.com: Put the fun back into computing. Use Linux, BSD.
                        If your hardware is Pentium based and has the IDE/PATA HDD cables, then the Linux Lite OS or Puppy Linux would probably work best. If your hardware is Intel Core 2 Duo & HDD with SATA cables, then Linux Mint would work Great for you!!![emoji6][emoji1303]
                          • 37558
                          Saved me having to pull my old XP laptop out and see if Firefox worked. The first PC I had on my desk at work was a dual floppy Cordata PC 400 with an Olvetti erename on it. Ran on MSDOS. Later replaced one of the floppies with a 5.25 inch 2.5MB HDD for some storage. First Windows systems were Windows 2.? And NT 3.?. Had to boot to DOS then load Windows. NT was their early server OS.
                            I have an XP pro machine.. I used today when my win10 battery went dead.. XP is running firefox will update on version later not round the ole tosh lapper
