I need to vent a little
  • tonerhead
    • Sep 2009
    • 582
    Yesterday afternoon I received a call to drive 150 miles for a line on the page. The customer wanted an eta. I called around 4:00 and did the usual troubleshooting over the phone. She is only getting a line when using the feeder, prints, and platen glass are fine. I told her to clean the scan glass. She got upset and said she cleaned it to no avail. When are you coming out? I have one call en route first so I should be out around noon. "I'm going to lunch at that time" How about 1? "I have an appointment at that time" Well if I switch the first call I be there around 11. "No, that won't work for me" "I need to get this fixed" Well what will work for you? "Can't you be here at 8?" Madam, that is a 150 mile drive, no I can't. I will leave at 7 and I should be there around 9-9:30. "Ok, see you then"
    I get there at the scheduled time, the door is locked, by appt only because of corona. I call, please continue to hold for next available person. 10 minutes later she picks up phone. 5 minutes after that she finally unlocks door for me to enter.
    She takes me to the copier and shoves a copy in my face "see this is what it is doing" I printed out a counter sheet and it was fine. I ran it through the feeder and lines. While she was standing there I took the copy with lines and put it on the platen glass face up. I told her to look straight over to the scan glass following the lines. Do you see the blob of ink on the scan glass? You need to clean here.
    Then she got upset with me. "Last week I called in for service and they told me the same thing" "So I cleaned the glass last week and the line went away" "But now it's back and I can see the ink you are pointing at" "I want to know why that copier keeps putting ink on that glass slit" "I WANT THAT FIXED"
    If I would have said what I was thinking, it probably would have gone bad for my continued employment. Instead I told her the ink is from your originals. "It can't be" Yes it is (and I left) Probably get a bad review with online survey they get after each call but wtf??? You can't fix this customer.
    I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
    Especially when it comes to sex
  • qbert69
    • Mar 2013
    • 1152
    Re: I need to vent a little
    Lady! LET THE G0DD@MNED GEL PEN INK DRY BEFORE RUNNING IT THRU THE ADF!!![emoji2959][emoji23][emoji38][emoji1787]
    ...do an ink dry time smear test right in front of her!!! Gel ink vs standard ball point pen....[emoji57]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 22999
      LOL. Rest assured some customer behaviors cannot be fixed. =^..^=
      • TonerMunkeh
        Professional Moron
        • 3865
        There's a phrase I like to use - you can't fix stupid.
        Hit it.
        • emujo2
          • Mar 2017
          • 1579
          I can explain it, but I can't make you understand..I would also point out that she is running non suitable originals thorught the ADF and future servcie calls for this will be billable. That usually stops just plain lazy calls, or maybe just increase the wait time each time she calls it in..by the 4th time and she's waiting 2-3 days she might get the hint..E
          • tsbservice
            Field tech
            • 7981
            This is written in every user manual and some machines even have a strip with instructions right on DF or scan glass. She can bitch but when it comes time to change toner or WTB will she call a tech? No Ma'am it's not tech job it's user job. I would bill her and all customers like her definitely.
            • copier tech
              • 8131
              You need to improve your phone skills.
              TELL the client if she is getting a line on copies & scans ONLY but none on prints, the ONLY cause for this will be a dirty scan glass.
              Once she tells you she has cleaned the scan glass explain that if you attend & find the issue is a caused by a dirty scan glass she will incur a call out change.
              They will soon learn.
                I have had some that state " I have a contract with you people COME AND FIX IT " I state ma'am/sir if it is a matter of cleaning the slit glass, and I provide instructions on how to clean it, and I HAVE to come out for it.. there will be a service charge and travel time if needed.
                they hang up and call the owner ( I was in his office ) he repeats what I said and she demands we come get our equipment " No Ma'am you bought that outright we have no legal grounds to pick it up....
                she cleans the slit glass and calls back " WELLLLLLLLLLL I fixed it" yes ma'am because of our EXPERT Advice.
                • tonerhead
                  • Sep 2009
                  • 582
                  I know what you are saying. However, billing can really backfire on you too. You upset a customer and they tell 10 of their friends that you are a money monger. Since this was my first time at this customer, I give them a freebie. Should this happen again I'll remember and read her the script about billing for ink on scan glass.
                  I've been burned more than once to actually find dust on mirror that only shows up for a doc feed scan.
                  It's just this customer's attitude and the fact that "the copier" put that ink there is the reason to vent.
                  It's customer's like this one that make me want to empty a waste toner bottle over the top of their head.
                    • 37377
                    I have had that as well. the projection path does not use the exact same part of the mirror for the entire length of the scanner bed. Dust stop lines on copies made from the platen glass can start 2 or 3 inches in from the edge and get wider as the scanner moves.
                    I have also had the line be caused by an hair line scratch on the slit glass.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      • gneebore
                        • Feb 2010
                        • 555
                        It's been a while but we had the same problem with fax machines sending lines to every other fax they send to. Had a few that by the second thirty minute drive to get there and clean white out or ink off of the scanner and showing the customer to just run a copy and check the optics that way. If the copy had a line not on the orriginal then lift the top like clearing a paper jam and clean this little bar right here with a paper towel dampened with alcohol or windex. There were plenty of times I actually showed them the white out on the scanner bar. A few customers also came up with the "I have a contract so you are going come here to clean it" And usually the owner of my shop would take the time to fax a copy of the contract with the clause about "repeated cleaning of ink of other dried liquids is not covered under the terms of the original warranty and our service contract" Then he specifically told them the next call for lines on sent faxes are billable for cleaning problems. Lost a couple contracts until they bought a replacement from the big box stores and found out the "onsite service under warranty" was provided by a company that was over two hundred miles away. otherwise they had to carry it in to guess who, our company. And they refused to fix any cleaning issues under warranty for free
                          • 37377
                          I had a fax machine at a Chevrolet dealer where it turned out to be the light bar.
                          As for white out, I had a machine at a company that worked with county child protective services doing counseling of children in foster care. There was a huge smear of white out on the slit glass. When I showed it to one of the owners she went ballistic. By law if they make an error on a document they are supposed to retype it. No corrections allowed.
                          • gneebore
                            • Feb 2010
                            • 555
                            Oh there were a few light bars that went bad or had cracked glass shields and we replaced them when they were. But I usually did a quick printout of the machine specifications and if it had no lines I then copied that. Lines, i would immediately clean the lightbar/scanner. And then run another copy. No lines they got a bill on repeat calls, There were times with an led scanner that a line of black ink was not visible but cleaning took care of that anyway. Even went so far as to use a clean plain white paper towel without any liquid on it. And then ran a copy that came out clean. Then showed the customer the now smudged paper towel. Eventually we quit working on the thermal fax machines because the price of the newer plain paper fax machines were dropping enough that it would actually cost the same to repair as it would to replace.
                              • 22999
                              Do you remember the Canon faxes with the square rollers? When the rubber wore through it would drop into the CCD optics causing a line. As they got older you could see the cracks, and know that just touching them would make them crumble. =^..^=
