Re: Remember when.... comments welcome.... your first servicing days with copiers
Apeco used to have a model that had telephone type rotary dial to use for setting the number of copies you wanted. Technicians called it the dial-a-jam.
Remember the deli slicer (cheese cutter) copiers. Operators got upset about registration issues on long runs. I handed out more than one bulletin from the manufacturer direct to the customer saying for long runs they were to tape the original to the platen glass to prevent movement. I remember one cheese cutter had a doc feed built onto it. Talk about having too much saki for the engineers that came up with that idea. I remember a Toshie that had a manual duplex. The first side went into an internal holding area and would stack about 25. Then you would reload into the paper tray and send it through for the second pass to the exit tray. Good times.
One of the oddest copiers I have ever seen were the "book copiers" We sold these to a lot of libraries. I forget the manufacturer, but they were Panasonic engines. The scanner area was totally redone. The right side of the scan glass was against a 45 degree drop on the right side of the machine. This was so books could be scanned without wrecking the binding and there would be no book bind shadow in the middle. It actually worked well. It was up to ledger size paper. For ledger sized paper the scanner would start where they start today on far left. For letter sized paper, the scanner would start in the middle of the glass and scan to the right side end of glass. If a library patron wanted a regular copy, they would put their original on the far right side of glass.Leave a comment:
When I started, "way back" in 1981. Most copiers still used liquid, although plain paper was really making headway.
I HATED having to clean out tanks. But, in the midwest, if you were low on gas, the dispersant could get you down
the road to a gas station. Even better in the summer if you had the dispersant already mixed with the ink. Made a
good FOGGER!
Machines back then had basically bicycle chains, switches and a huge cam for the timing. Fax machines were a separate
item, as were dot matrix printers.
Troubleshooting? IF you were lucky, inside the door was a 1-9 counter that you could look up in a book for "some" help,
but troubleshooting was basically mechanical troubleshooting, or pulling jams out. A LONG PM cycle was around 6-7 thousand
copies. Moving tops. Then came "finishers". I remember the first one I saw (Sharp) was a 20 bin finisher, that was about 7 feet
tall, weight more than the copier, had a tray arm to reach the copier output (Sharp SF-811), and you really didn't want to be
in the same room when it was on, because of how loud it was.
You had a box full of manuals, that really didn't help you a lot, but was one of the reasons your service vehicle was either a pickup
truck with a camper shell, or, a full size fan, so you could pick up and move machines around, on what looked like a "body cart".
Copy quality? If it came out of the machine, without lines or streaks, and you could read it, it was "good enough".
Now, everything is networked, machines are MFP's. Copies look better than the original, most of the issues I have these days are
network issues or SOFTWARE issues.
I remember when the paperwork reduction act came along, mid 80's, someone told me I'd be without a job soon.
I just laughed. I said as long as there are politicians & lawyers, there WILL be paperwork. When computer & the internet came
along, it just exploded.Leave a comment:
good FOGGER!
I must have been one of those groundbreaking techs. In 1989 I started with the white or blue short sleeve shirts and ties. It didn't take long for me to figure out that the blue shirts lasted longer. Within a few years I had entirely switched over to gray and black shirts.
In the 90's I wore a lot of those cartoon character ties, and some pretty garish colors. I might still have a few ... =^..^=Leave a comment:
jammed = 10_01_13_13_05_04
A lot of digital phones stopped making tones after ~50 button presses, which comes up surprisingly quickly when you've got to order parts, and enter a 5 line description. The pocket dialer was a life saver. I think it's still around here someplace. =^..^=Leave a comment:
The nipped-off tie fed all the way through and landed in the exit tray with the Seldrum Space Shuttle copied onto it. =^..^=Leave a comment:
A lot of my customers only had rotary dial phones, so I used one of those handy dandy pocket dealers every day.Leave a comment:
I remember my boss getting a tie caught in a running copier and it sucked him into it. The gal in the office saw it and smart thinking grabbed a scissor to cut it off. Boss was pissed about losing his tie.Leave a comment:
Yeah, we did too. Forgot about that (33+ years ago). I quickly learned the best color for a tie was black so that whenever I had to adjust it, if it got toner/grease from my hands it wouldn't show up. Ah, the good ol' days.Leave a comment:
From day one I had to wear a dress shirt and tie. Color was optional. All of the techs wore a short sleeve dress shirt with a tie. That's retarded.Leave a comment:
Not parts/supplies related, but remember the dress shirts/Ties..My 1st day training, I'm walking into an office white shirt, black tie, my mentor dressed the same..I say " man I feel like one of those, what's the name?? You know religious sect??? He says Jehova Witness?? I say YES!! that's it..Turns out 10 of the 11 guys in the office including the manager are all Jehovas...30 years later, the ones that are still alive I am still friends with. E
Also being a agricultural and and oil production economy you did not want to overdress. Many local businesses would rather do business with a sales person wearing Levis and a t-shirt than one wearing a 3 piece suitLeave a comment:
