What is appvlp?
    • 23008
    What is appvlp?
    A few days ago it started: when I attempt to open .xls or .xlsx files in Windows 10, I get a blank Excel screen. I can then browse to: Open > then find the file, and it still opens properly, but just double-clicking the filename cannot find the file.
    In Settings > Apps > Default Apps almost all file types default to "appvlp" whatever that is. I have Microsoft Office 2013 and the appropriate license, but cannot see a way to select the on-board Excel application.
    Does this sound familiar? =^..^=
  • luca72
    • Oct 2017
    • 1778
    Re: What is appvlp?
    if you do "open with " and select "excel" and select "always" doesn't it remain stored?
    I would try to do it a registry cleaning with one of the many software avaliable, in order to try to correct the bad entries, and an office restore.
    "I'll be back"
      • 16391
      Re: What is appvlp?
      It appears that you're not the only one with this problem.
      I'll include the link but this is the solution listed:
      Here is the solution:
      1. Start any office app, e.g. Word, from the start menu (start button / Microsoft Office 2013 / (app). This link should work; it's only links that have been copied to desktops, taskbars, etc. that don't.
      2. Click on a blank document (or workbook, or whatever) to get to a regular document window. Then use File / Account to open the account/version/activation screen. Click the Update Options button and select Disable Updates from the menu. This is important because you don't want your computer downloading the update again after you uninstall it!
      3. (Note you can also do steps 1 and 2 only to proactively prevent any computer running Office 2013 64-bit from updating if it hasn't done so already. The installed version will show on this screen, and if it's earlier than 15.0.5589.1001, just turn off updates and you will have dodged the bullet. Congratulations, you're done.)
      4. Assuming you have been updated, close the office app you have loaded and any and all other Office 2013 apps.
      5. Open an elevated command prompt (run cmd.exe as administrator)
      6. Change to the Office 2013 click-to-run base folder:
        cd "%ProgramFiles%\Microsoft Office 15\ClientX64"
      7. Revert to version 15.0.5571.1000, which does not have this bug:
        officec2rclient.exe /update user updatetoversion=15.0.5571.1000
      8. Wait a bit. Be patient, it takes a few minutes. You will see a box pop up (not immediately, don't worry) informing you that updates are being downloaded; then that box will close and another will pop up telling you that updates are being installed. When this second box closes, you are done.
      I've done this on few computers so far and it's worked flawlessly.
      https://learn.microsoft.com/en-us/an...resently-confi
        • 23008
        Re: What is appvlp?
        Thanks Billy! Clearly I have not dodged this bullet.
        I'll give it a try. =^..^=
          • 23008
          Re: What is appvlp?
          I did think of that. The only choices of applications to open Excel docs are "appvlp" or "select an app from the Microsoft Store", and no option to "Always use this App". If I browse to Excel 2013 executable, it still does not open the file, I just get another empty Excel window.
          I'm starting with Billy's suggestion, thanks. =^..^=
          • massop
            • Sep 2023
            • 1
            Re: What is appvlp?
            This worked perfect for me. Thanks
            • Ton
              • Sep 2023
              • 1
              Re: What is appvlp?
              Thank you very, very much!!!
                • 16391
                Re: What is appvlp?
                I'm always suspicious of first time posters randomly popping up thanking me. There's 2 in this thread. Maybe I'm just paranoid.
                Anyway, blackcat, did you have any luck getting your issue resolved?
                  • 23008
                  Re: What is appvlp?
                  I've been otherwise occupied. I'll take a shot at it this weekend. But thanks for asking. =^..^=
                    • 23008
                    Re: What is appvlp?
                    Office "The operating system is not presently configured to run this application" - Microsoft Q&A
                    It worked like a charm.
                    It took a little searching to find the place to shut off the Microsoft Office updates only: Start Menu > Excel 2013 > Open Other Worksheets > Account > Update Options > Disable All Updates > Close.
                    ... and yes, it was at version 15.0.5589.1001
                    Thanks for the help! =^..^=
                    • Larhal
                      • 571
                      HMMMM. Last Post is in Spanish? and Donna is in Berlin???
                      Larhal
                      If all else fails read the Service Manual!
                      If that fails, meet me at the pub and we will discuss it.
                        • 23008
                        Yeah, Donna is clearly a spammer trying to sell some sort of activation software. Interesting the Spanish text, and Germany as country of origin.
                        • Larhal
                          • 571
                          No, No lo creo, tambien hablo vatios idiomas.Tu publicacion parecia SPAM.
                          Larhal
                          • Lukkee Gonzalez
                            • Dec 2024
                            • 1
                            ¿Alguien sabe cómo activar MS Office 2021? Lamentablemente la activación no funciona, pero debería funcionar. Todavía quedan 4 meses. No quiero escribir al servicio técnico. Tardaría mucho tiempo. Me gustaría activar el programa y no comprar más al menos temporalmente.
                              • 37489
                              Does anyone know how to activate MS Office 2021? Unfortunately activation doesn't work, but it should work. There are still four months left. I don't want to write to the technical service. It would take a long time. I'd like to activate the program and not buy any more temporarily.
                              You will most likely need to contact Microsoft Support. You will probably have to purchase an activation key for each PC you need to activate it on.
                              Lo más probable es que necesite ponerse en contacto con Microsoft Support. Probablemente tendrás que comprar una clave de activación para cada PC que necesites activarla.
