Touch Panels once again.....
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    #31
    Re: Touch Panels once again.....
    Originally posted by Hansoon
    Now I'm confused. What goes to what?
    Also, do all of the above touch panels have the same failure rate? Which one would be the most important to have in stock?
    Hans
    the B223 and the H310 are the most common failures. However you can't get the xxxx9900 panels from mother Ricoh any longer, the 9900 panels were no charge parts shipped from Ricoh to dealers based on machine population. Now you have to order the correct part # and pay Ricoh's nominal fee.......
    Mystic Crystal Revelations
    • Hansoon
      • Sep 2007
      • 3391
      #32
      Thanks Tonerbomb.
      Hans
      • Hansoon
        • Sep 2007
        • 3391
        #33
        Guys, please, before I jump off a cliff, please tell me to what Kyocera machine / series this control unit belongs.......
        Hans
        • Debs1964
          • Oct 2010
          • 1693
          #34
          I've only ever had to replace one H310, however I have replaced loads of B223 and D029
          There are 10 types of people in this world, those who understand binary maths and those who don't
            • 23009
            #35
            It's the same generation as the CS-C4035 and the CS-8030. To tell for sure, what is the part number on the op panel PWB? There will be at least two numbers printed on it: one is the PWB assy, the other is the blank printed circuit board. Include both numbers. =^..^=
            • Hansoon
              • Sep 2007
              • 3391
              #36
              Cat, this is what I have:
              • katash
                • May 2010
                • 221
                #37
                Not responding touch panels often can be repaired as long as the problem lays in the connection of the flat ribbon cable.
                However, many customers irritated by the non responsive Touch Function use excessive force and sharp objects such as pens to operate the panels. Furthermore some of our colleagues try to revive not responding Touch Panels by putting them in an oven at high temperatures. This all results in invisible damage to the thin plastic foil on top of the glass pane making a repair impossible.
                For this reason we intend to supply in the future brand new aftermarket Touch Panels in such cases where repair is not possible anymore.
                To offer a complete assortment for as many models we like to know once again which models from what manufacturers are suffering from not responding Touch Panels.
                Kindly post here the manufacturers name and model knowing to have been affected.
                Many thanks in advance
                Hans
                touchpanel[at]rex-technika.com
                mpc 4500 mpc2500 ricoh
                • Kidaver
                  Ghoulscout
                  • Apr 2011
                  • 912
                  #38
                  Hans that looks a lot like a 3050, 4050, 5050 op panel...but that's just eyeballing it.
                  "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                    • 23009
                    #39
                    The 2GR part is the product code for the CS-5050 or KM-5050, like Kidaver said. =^..^=
                    • mad
                      • Jul 2010
                      • 25
                      #40
                      do you have a front panel picture?
                      or what are the screen dimensions?
                      • mrwho
                        Major Asshole!
                        • 4299
                        #41
                        Didn't read the whole thread, so sorry if I'm going to ask a question already answered:
                        Do you have a catalog online where we can check and order those panels? Where do you ship from and do you ship worldwide?
                        Cheers!
                        Mascan42
                        Ibid
                        • Hansoon
                          • Sep 2007
                          • 3391
                          #42
                          No website (yet). Sorry.
                          We have as follows:
                          A) # 4037-7807-01.01
                          Touch Panel, compatible for use in:
                          Develop ineo + 350, ineo + 450, QC 2235plus,
                          ineo + 300, ineo + 250, ineo + 351, ineo + 251
                          Konica-Minolta bizhub C 250, bizhub C 350,
                          bizhub C 450, bizhub C 351, bizhub C 300,
                          bizhub C 352, bizhub C 252
                          Olivetti d-color MF 22, d-color MF 45,
                          d-color MF 25, d-color MF 30, d-color MF 35,
                          d-color MF25 plus
                          Color Models
                          OEM PN: 4037-7807-01 / 56AA87551
                          B) # 4040-7809-01.01
                          Develop ineo 250, ineo 350
                          Konica-Minolta bizhub 250, bizhub 350
                          B&W Models
                          OEM PN: 4040-7809-01
                          C) # 20052012
                          Konica-Minolta, bizhub C 203, bizhub C 353
                          Develop ineo + 203, ineo + 353 only
                          Olivetti d-color MF 201 plus, d-color MF 350,
                          ONLY FOR ABOVE COLOR MODELS!
                          OEM PN: none, used in Control Panel #A02E M710 02 only.
                          D) # 20102012
                          Konica-Minolta, bizhub C 253
                          Develop ineo + 253
                          Olivetti d-color MF 250
                          OEM PN: none, used in Control Panel #A02E M700 01 only.
                          E) # 302FB25191.01
                          Kyocera-Mita KM-C 2520, KM-C3225,
                          KM-C3232, KM-C2525E, KM-C3225E,
                          KM-C3232E, KM-C4035E, KM 6030,
                          KM 8030
                          Triumph Adler DCC 2520, DCC 2625,
                          DCC 2525, DCC 2532, DCC 2632,
                          DCC 2635, DC 2060, DC 2080
                          UTAX CDC 1520, CDC 1625, CDC 1525,
                          CDC 1532, CDC 1632, CDC 1635, CD 1060,
                          CD 1080
                          Color Models
                          OEM PN: 302FB25191
                          F) # 302H094271.01
                          Kyocera-Mita KM-2560,3060, Taskalfa 300i, / Copystar CS2560, 3060, CS300i
                          OEM PN: 302H094271
                          G) # 302GR45040.01
                          Kyocera-Mita KM-3050, KM-4050, KM-5050 (I) / Copystar CS-3050, CS-4050, CS-5050
                          OEM PN: 302GR45040
                          Contact us please for a quotation:
                          touchpanel[at]rex-technika.com (replace [at] with @ because of spammers.
                          Hans
                            • 23009
                            #43
                            E) # 302FB25191.01
                            KM 8030
                            CD 1080
                            Color Models
                            OEM PN: 302FB25191
                            Hans
                            Within E) you can also include: KM-2540, KM-3040, CS-2540, CS-3040
                            • Hansoon
                              • Sep 2007
                              • 3391
                              #44
                              Great! Good to know. Thanks Cat!
                              Hans
                              • Hansoon
                                • Sep 2007
                                • 3391
                                #45
                                Hans
