What's the most whack customer description???
  • Dalamar
    • Oct 2006
    • 117
    #46
    "my machine is jamming"
    "where?"
    "all over"
    just annoying.
    bank mangaer to us
    " our machine is dirty why not give it a good douching"
    Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
    SCREWTAPE - "Try harder.."
    • Jimbo1
      • Mar 2008
      • 845
      #47
      "When I turn it on the little bowling pins light up and the wheelie deals just keep turning."
      ----Trying to add toner.----
      "Some days you get the bear, some days the bear gets you."
      Cdr. William Riker
      • barratec
        • Jun 2008
        • 162
        #48
        the machine doesn't turn on
        ....the machine wasn't plugged in!!
        • Bill T.
          • May 2008
          • 45
          #49
          And why is it no matter the problem customer ALWAYS says " I think it the rollers"
          Only one man in a thousand is a leader of men -- the other 999 follow women.
          • lkrsardis
            • Dec 2007
            • 316
            #50
            ignit
            "You mean you have to take the wrapper off the paper?"
            Like the United States Postal Service It's a miracle it works!
            • Fangers
              #51
              Originally posted by lkrsardis
              "When I feed my originals they come out with spots"
              Originals fed through the bypass. Dumbass!!@
              LMAO one of our storemen was checking the copy quality on a machine before he boxed it up to go north. We had already checked the machine so there was no real need. I look up to see my test chart slowly going into the bypass... I've never lent him another test chart since...
              • djbass
                • May 2008
                • 165
                #52
                true that, or 'It needs a clean & service'.. expecting every niggling problem must mean it needs to be stripped down and given a full service, even if one was only done a week before.
                No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
                • Fangers
                  #53
                  Some customers like to tell you what's wrong with the machine. Hand them a screwdriver and it's a different story.
                  Originally posted by 10871087
                  Every Mita tech has had this phone conversation at some point in their career
                  Customer: I need service, my machine only makes one copy at a time.
                  Tech: Is your "add toner" light on?
                  Customer: Yes, but it only makes one copy at a time
                  Tech: That's because your add toner light is on. Remember you had the same exact problem last month when your "add toner" light was on.
                  Customer: I know, but it only makes one copy at a time
                  Tech: That's because your "add toner" light is on
                  Customer: I know it needs toner but it only makes one copy at a time
                  Tech: It is supposed to do that, until you add toner it will only make one copy at a time.
                  Customer: Even when I put the original on the glass, it still only makes one copy at a time.
                  Tech: what part of "add toner" is most difficult for you to understand?
                  Customer: My machine only makes on copy at a time
                  Tech: Do you have any toner?
                  Customer: Yea, but I think my machine is broken, it only makes one copy at a time.
                  Tech: Argh, OK, I swing by this afternoon and see if I can fix it for you
                  Customer: Fix What?
                  Tech: Your copier
                  Customer: Oh yea, did I tell you it was only making one copy at a time?
                  I'm pretty sure there's something you can do in service mode that allows normal copying with low toner.. I personally think it's good because you can charge contract clients for a negligence call xD!
                  • laserman06
                    Conservative in Exile
                    • Dec 2007
                    • 323
                    #54
                    Don't laugh, had that happen to me. Called for jamming out of paper tray.
                    It was in a lawyer's office, no less.
                    The family that prays together, stays together!
                    Smile God created you and He doesn't make mistakes!
                    Relax, God IS in control!
                    Be still and know that I am God
                    Ps 46:10
                    • SGT_Snacks-64
                      • Oct 2007
                      • 157
                      #55
                      "Copier dead"
                      Cause -: Customer had ripped the power cable out of the plug, which was still in the socket.
                      Charged due to Health and Safety negligence and more so to the fact that they ripped the cable out of the plug. What were they expecting?!?!
                      I've had another one where the trip switch for the power in the Copier room went. Took 30 minutes to get the Caretaker/Janitor to atleast check the switch.
                      Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
                      Asus P5E-VM HDMI
                      4GB (2x 2GB) Corsair XMS Xpert II RAM
                      ATi Radeon 4870 512MB GFX Card
                      2x 74GB WD Raptor Sata HDD (RAID 0)
                      500GB Seagate Barracuda Sata II HDD
                      500GB Hitachi Sata II HDD
                      600W500att OCZ PSU
                      -TOTAL HDD SPACE 1148GB-
                      • Jimbo1
                        • Mar 2008
                        • 845
                        #56
                        That @#$#%!&# Scan Glass!!!!
                        "But I cleaned the glass."
                        --Yes Ma'm, but we meant the little one here to the left.
                        "Oh that one!"
                        --Yes m'am, if you get just a spot on that it turns into a line.--
                        "Oh well I'm sorry you had to drive all that way for just that."
                        --That's ok. It's needs some cleaning anyway.--
                        Cdr. William Riker
                          • 23008
                          #57
                          Jimbo, I wish I had a nickel for every time I've had that exact conversation.
                          • Jimbo1
                            • Mar 2008
                            • 845
                            #58
                            The fun thing about that one is it is universal because every digital copier with a doc feeder has that stupid little glass.
                            I actually got in trouble once for explaining about that glass and what happens when you get a spot on it. Girl called in and said I was being "condescending".
                            Still had to clean the glass.
                            Cdr. William Riker
                            • hodgiepodgie
                              • 284
                              #59
                              Or The Guy Who Went Berserk When I Began Vaccuming A 6010
                              • costd
                                • Jan 2008
                                • 409
                                #60
                                School got a new copier and salesman was scheduled to demo it a couple days later. They could not wait and tried to make copies. Turned in service ticket as the machine would read the documents in and make "noises" but did not produce any output. Got there and they showed me - their old machine had a right side output tray (new machine it is the bypass). Output tray on new unit is below the reader. Showed them and their only comment was "oh, you mean we will need to look under there if it fails to come out where it is suppose to?"
