Vacation ... sort of
  • igi
    • 1507
    #46
    Re: Vacation ... sort of
    Great forum! Thanks igi. I think she'll like the site. She's not really a silver surfer, though. =^..^=
    happy to help BC
      • 22997
      #47
      Originally posted by Lagonda
      Sudden after thought.....while you've got the toilet pan out consider replacing it with a disabled / handicapped one as their about 2 inches higher. It doesn't sound much but anything that helps crook knees will be appreciated. A good solid grab handle to help pull yourself off the dunny will go down a treat as well when Mrs BC gets home.
      Yes, both toilets are the 21" variety, 2" taller than standard. I'll probably put in the grab handles anyway, even though she says she doesn't need them. I'm going to pick her up now. I'm pleased how quickly she's progressing. =^..^=
      • NeoMatrix
        Senior Tech.
        • 3514
        #48
        You can mount the pan on another 2" block of wood/concrete to lift the toilet up higher still.
        Hope Mrs BC is on the legs and walking soon...
          • 22997
          #49
          Mrs. blackcat is home as of 1600. She stepped in with the walker, no assistance but my stabilizing arm at the stairs. The trips to the rest room get her 35 ft of exercise every 2 hours.
          The washer and dryer are installed ... and hopefully still functional, I haven't tested them yet. About 1/2 of the trim is painted and installed. Grab bars installed. There's some rough spots in the drywall in need of filling, some trim and trim painting. Then first room done.
          She seems to have survived my first attempts at cooking in 30 years. Rice and frozen egg rolls (no silly, I cooked them. You could break a tooth on the frozen ones). I'm not very adventurous, but Mrs. blackcat won't starve.
          Next adventure is to see if I can do laundry. Wild times ahead! =^..^=
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            #50
            Glad to hear Mrs. BC is home and surviving your loving care...........I haven't been around that much lately as my SM had a heart attack and a small stroke last week. My work load has doubled,tripled??
            Now remember to put all the whites and the reds in together, use some extra bleach to get the whites clean and hot water temp. When done put all the pinks in the dryer on high heat for 1 hour, remove and fold all the little pink clothes...............
            Mystic Crystal Revelations
            • ZOOTECH
              Senior member of CRS
              • 3375
              #51
              Fixed it for you.
                • 22997
                #52
                I don't need that kind of help, thanks.
                Do you think the cats missed her? Yes all four found places to sit. =^..^=
                  • 22997
                  #53
                  Mrs. blackcat is doing fine thanks. I've managed not to poison her so far. The laundry is done. I even did something off the honey-do list (de-greased the stove). It took all day. That's what you've got to look forward to Neo.
                  Mrs. blackcat is comfortable enough with her ambulatory skills that I can head back to work Monday/tomorrow. She seems to have the pain under control.
                  I tried to sleep downstairs on the army cot the first night. The idea was for me to be close nearby, in case my patient needed anything. The cot was uncomfortable, and it was a miserable failure. I got a total of 1/2 hour sleep and a kink in my back. At 4:30 I finally went upstairs and got 4 hours of decent sleep. I took all day to work out that kink.
                  Oh, and does she have Olympic class bruises! Between the surgery and blood thinners, the surgery leg is bright yellow, ankle to thigh with beautiful purple and green highlights. I still haven't seen the scar yet. It's got a self-adhesive bandage that's very securely attached. Doc says the bandage will fall off eventually, by itself.
                  I'm learning how to become a better server. This might surprise you but I am not, by nature, a patient person. I seem to be learning patience though.
                  The insurance company has sent out a RN. As far as I can tell, her only purpose is to nose her way into every crevice of our lives. One more visit like the last, and I'm sending her packing. =^..^=
                    • 37354
                    #54
                    Sometimes the RN sent out to evaluate the home situation and plan the physical therapy sessions are a major pain. Usually the therapist is much less intrusive.
                    • Lagonda
                      • Aug 2008
                      • 1649
                      #55
                      Why has the Royal Navy turned up for a look at Mrs BC?
                        • 37354
                        #56
                        State side RN = Registered Nurse
                        • Iowatech
                          Not a service manager
                          • 3930
                          #57
                          As someone who may have spent a few nights on an Army cot, here are some suggestions you may wish to consider that might make it less uncomfortable next time you have to use the thing.
                          If your cot has a crappy mattress on top of a wire mesh suspended by springs from a steel frame, see if you can find some thick cardboard to cover the entire wire mesh under the mattress, that will simulate box springs to some degree and actually makes quite a difference. Plywood works even better, but can be harder to come by at night when the cot is unexpectedly needed. Cardboard is easier to dispose of in a hurry, too.
                          If your cot has a piece of fabric attached to an aluminum frame, make sure to put both end pieces on the cot. Its kind of tough, but if you don't put both end pieces on the fabric will ride up and you'll be lying on the stupid middle legs, which makes it even more uncomfortable.
                          Also, lay on your side if at all possible. If you lay on your back on that type of cot, it's natural curvature will position your body in unnatural and weird positions, which at least caused me to probably suffer similar discomfort as you a couple of times.
                          A reasonable facsimile of a pillow of the correct size that will keep your head at least mostly aligned with the rest of your body is really important.
                          Finally, if you have a durable blanket (one that you and Mrs. blackcat don't mind throwing in the washing machine when it needs it) which is more than twice as wide as the cot, first cover the cot with around half of the blanket, then lie down on the cot, and then cover yourself with the rest of the blanket. That might not make the cot much more comfortable, but at least you'll be warm. And it is pretty easy to get out of that arrangement rapidly if you have to.
                            • 22997
                            #58
                            Mine is the green canvas and aluminum tubular frame. and yes it's not quite wide enough to lay on your back without all your limbs hanging off. The few times I did fall asleep I had a cold piece of aluminum across my cheek. The heavy blanket would probably help. I did OK in the summer. Maybe it's the temperature that makes the difference. We're getting 50 degree nights. =^..^=
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4714
                              #59
                              [ATTACH=CONFIG]26383[/ATTACH]
                              Only 4? You sure are slacking off BC. I will serve breakfast to 8 of those little muchers, down from a high of 15.
                                • 22997
                                #60
                                We had 8 at one time. As far as I can tell there are only a few guidelines:
                                1) Only one male. Two males is too many.
                                2) Make sure the newbies are healthy kittens. No adults, no runts, no sick animals.
                                Our new crew has much less in the way of personality, behavior, and health problems now.
