peaking skids argg
  • Lagonda
    • Aug 2008
    • 1649
    #16
    Re: peaking skids argg
    Originally posted by CompyTech
    ....... it's all bent up but the box is fine...........
    Sometimes I wonder if transport companies go to the trouble of carefully unpacking equipment, beat the crap out of it, then carefully pack it back up again. Why? who knows, but if they do it just to piss you off, they are succeeding!
    • KapeKopyTek
      • Nov 2013
      • 284
      #17
      Originally posted by allan
      Golden rule. Never unbox a machine at the customer.
      We've recently (within the last 6 mos or so) begun to Prefight EVERY machine that comes to us from either Ricoh/Savin or Konica. Too many of both bad out of the box - does not impress the customer when unboxing on location and it doesn't work! We've had bent frames, broken optics, bad psu, bad pcb, etc, etc, etc......
      • copyguy1
        • Jul 2011
        • 142
        #18
        We unbox all machines within 10 days of getting to us. We have had enough of the damaged. Then take pictures and get them sent back for credit.
        • Phrag
          • Oct 2012
          • 417
          #19
          We've had similar experiences with Konica Minolta.
          C360's stacked on top of one another. We kicked up a stink about it, as not only can it severely damage the machine frame, but who in their right mind would want to HAVE to lift a 100kg brick from shoulder height to the ground?
          Turned out the freight company/ies were stacking them to fit more into the trucks.
            • 23010
            #20
            I happened to be on hand when one of the trucks arrived.
            When the driver opened the back, at least 6 of the boxed copiers were laying on their sides and at odd angles. He seemed a little surprised when I started snapping photos. If any of that machinery was busted up, I wasn't taking it. And I did unbox every piece of that order before the truck left. Surprisingly, no damage. =^..^=
            • SargeNZ
              • May 2012
              • 263
              #21
              We had a ricoh come in that looked fine but was throwing laser motor codes. Pull the laser and the top half of the laser motor is just rattling around in the enclosure. The machine had to be upside down for some part of it for that motor to come out of it's housing like that.
