FOOD
Re: FOOD
Start by slightly under cooking boiled potatoes.
Cut them up in a bowl until fine but not to fine leave a little texture.
Mix some egg white, corn flour and water to make a binder. About one large egg white to 4 medium potatoes.
Wait for the potatoes to cool down.
Cut some mixed herbs (dried), salt, pepper and the binder into the potatoes.
Make palm sized oblong balls from the mix.
Heat up a 1/4 of an inch of cooking oil in a pan and fry until golden brown.
Thanks to the American fast food revolution.WhateverComment
Re: FOOD
Attached FilesNEVER ASSUME ANYTHINGComment
Re: FOOD
We bought the cooker new and never needed to replaced the lid seal for years on end. Now all we seem to do is buy a new $30 seal every 12-18 months.
I appreciate any hints or tips to make a good Lid seal out of 'X'-material.Last edited by NeoMatrix; 02-19-2016, 10:17 PM.Inauguration to the "AI cancel-culture" fraternity 1997...
•••••• •••[§]• |N | € | o | M | Δ | t | π | ¡ | x | •[§]••• ••••••Comment
Re: FOOD
We've own a twist-lock lid style pressure cooker for 30+ years. Is there anyway to stop the large 'O'-ring seal in the Lid from deteriorating ?
I appreciate any hints or tips to make a good Lid seal out of 'X'-material.Comment
Re: FOOD
I appreciate any hints or tips to make a good Lid seal out of 'X'-material.If you'd like a serious answer to your request:
Re: FOOD
To prevent oxidation of the metal, and to preserve the elasticity of the rubber seal, wipe the rubber seal with vegetable oil after cleaning, and before sealing up the cooker. We've had the same pressure cooker for 25+ years. We did purchase a seal kit a few years back, but not for the ring seal. The black plug in the lid was failing to seal, and not building pressure. =^..^=
I feel the propellant in the pressure pack can of vegetable oil is probably causing the problem.
The propellant must be a very thin hydrocarbon base oil because it turns the Lid seal to something like chewing gum within 12-18 months.
Only light viscosity oil like brake fluid/WD40 is able to penetrate into rubber an do those kinds of softening reactions.
I'm thinking of making a new Lid seal out of silicone rubber. Silicone will resist heat up to 500degC. Silicone melts around 1400degC or there abouts.
Will play some more....Inauguration to the "AI cancel-culture" fraternity 1997...
Re: FOOD
Went to a Malaysian festival yesterday had some great food.
started with char kuey teow
very nice and reminded me of pad thai
Still hungry so I tried some curry laksa
This was awesome, first time I have had tofu
20160917_130310.jpgComment
