We have a daily joke, how about industry pictures?
  • theengel
    • Nov 2011
    • 1784
    #76
    Re: We have a daily joke, how about industry pictures?
    Originally posted by emujo
    I would think every manufacturer has this config for pulling paper...look at the locations of the feed and sep rollers...backwards..LOL Emujo
    Maybe I'm looking at a different picture. How can you even see the sep roller? The feed roller is driven by a belt attached to the PU roller. The sep roller is beneath the feed roller and PU roller. I still don't see the problem.
    • Coptech
      worker drone
      • 460
      #77
      Truth is that if you had worked on Konicas, you would have known the black ribbed roller was a pick up roller. They have it over the sep roller which is obviously wrong. Konica even used an additional weight over the pick up roller years ago which was when I was last around them and tipped me off to the machine type.
      • TheBlueOrleans
        • Aug 2012
        • 232
        #78
        Viewing that picture as posted, the problem is the Feed roller is switched with the Pickup roller, the Separation roller is present, but barely visible behind the metal plate. Pickup roller should be the "tire with the tread", as one of the locals so eloquently put it, and the feed roller should be the red/orange roller that is always backordered at the most inopportune time.
        I have seen the pickup roller replaced with an orange roller, function was fine. Maybe not supposed to be that way, but it worked.
        But the picture posted shows the "treaded tire" in the feed roller position, which is loads of fun if you want to screw with somebody, but it doesn't function very well.
        Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
        • theengel
          • Nov 2011
          • 1784
          #79
          Thankyou Blue.
          • NeoMatrix
            Senior Tech.
            • 3513
            #80
            haha..... zzzzzz....
            I was in Zzzz mode too....
            It all comes down to perspective and which angle you view the pic from...
            I was looking for clips out of position......... this forum is great......
            (No CTN thanks or like buttons ATM)
            • habik
              • 2013
              #81
              Question to customer: "Have you been printing labels lately?"
              "Noooo not at all!!"
              Are you sure?
              Yes, positive!!
              Erhmm with an Eagle piercing look and showing this .
              Byting on bits.
              Firmwares HERE
              • gerryproulx
                • Mar 2015
                • 24
                #82
                • Lagonda
                  • Aug 2008
                  • 1649
                  #83
                  Spot the problem!
                  Ricoh internal LCT.
                  Don't know how they managed that one but it took talent!!
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    #84
                    Originally posted by Lagonda
                    Spot the problem!
                    Ricoh internal LCT.
                    [ATTACH=CONFIG]33299[/ATTACH]
                    Surprisingly, not a sheet of paper out of place.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      #85
                      Spot the problem!
                      Ricoh internal LCT.
                      I once found a desiccated potato wedge under one of those. It was a MP4054. In a prison, in a wing where the prisons are locked up 23hrs a day. Fucking guards.
                      • Iowatech
                        Not a service manager
                        • 3930
                        #86
                        For what it is worth, I found that picture here.
                        (While I've found Izismile to be a decent site, as always open that link at your own peril.)
                        • qbert69
                          • Mar 2013
                          • 1152
                          #87
                          Spot the problem!
                          Ricoh internal LCT.
                          Jam Sandwich Mode!
                          REACH FOR THE STARS!!!
                          Konica Minolta Planetariums!
                          • Tonerbomb
                            AutoMajical Resolutionist
                            • Feb 2005
                            • 2589
                            #88
                            Originally posted by Iowatech
                            [ATTACH=CONFIG]33345[/ATTACH]
                            I think I've seen something simalar but it had more of a pink tint to it................
                            Mystic Crystal Revelations
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4713
                              #89
                              I did this in a doctor's office. They had carpet.
                              Multiply that amount by 15 and that's what I did in the headquarters of Army Special Ops Command.
                              • Iowatech
                                • 3930
                                #90
                                As someone who was probably only in the part time adequate forces, I hope they didn't give you too much crap for that.
