DF629 front to back adjustment
  • Sandy007
    • Jul 2025
    Hi, I have a brand new DF629 installed on a brand new C258, the copies on the glass are fine and square but through the ADF the copies are moving up the page by about 3-4mm and leave a dark shadow line at the bottom of the image. It is not skewing, how do i adjust the front to back scan image on the ADF, is it through the service mode (can't see it)? or is it a manual adjustment? Many thanks
    • 37520
    Re: DF629 front to back adjustment
    Why would you post a problem in the newbie forum? I would tell you which technical forum to use had you included the make of the machine as many manufacturers use the same or similar models. Post in the correct technical forum.
      • 23009
      Welcome!
      I believe that the manual covers this issue. Have a peek. =^..^=
      • Sandy007
        Welcome!
        Thank you for your quick response, i have since found the 'anti skew guide' which came in the box, doh!, and fixed the issue
        • Sandy007
          Thank you for your warm welcome to a Newbie I will definitely post in the correct forum from now on considering now i'm no longer a newbie.
          I have since found the 'anti skew guide' which came in the box, doh!, and fixed the issue
          Going forward i feel as though you have built up my confidence to post again, in the correct technical forum.
          P.S. It was a Konica Minolta make of machine.
