Copier says open component but every component is closed
    • 37480
    #16
    Originally posted by LOVABOY
    I see a lot of orange packing tape. Did you try to unpack it yourself and damage something? Most likely. Contact the seller to have a trained installer sent out.
    • femaster
      • May 2011
      • 1501
      #17
      The black trim panel below the LCT access door is missing, which makes me wonder if there was some damage done to that area of the machine, possibly in transport.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4680
        #18
        Remove 1 screw from small cover on rear of machine and check to make sure connectors are tight from base to copier.
        • tsbservice
          Field tech
          • 8008
          #19
          This ^
            • 37480
            #20
            Just because that lower jam door looks closed does not mean that it is. Most people close that door by lifting at the front. Try pressing in on the back top corner where the door switch is actually located.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4680
              #21
              Also if you still can't get message to go away you could remove the small cover on rear, disconnect both connectors from base and use just tray 1 & 2 until you get a qualified technician to repair. * NOTE: when ever connecting or disconnecting wires make sure power is off!
