Copier says open component but every component is closed
  • jemmanuil
    • Apr 2020
    • 3
    I own a konica minolta bizhub c452 used copier. The first time i turned it on it showed a little arrow on the screen indicating that the component door just under the inks is open. However, this door is closed. I tried turning on and off many times but the message persists.
    What can i do?
    Re: Copier says open component but every component is closed
    What can i do?
    as an end user do you have the knowledge to use a multi meter?
    if you intend on servicing this yourself ( NOT recommended ) you better buy/locate a service manual.
    what happens in you open that door? does the message stay the same or does it change.
    i would recommend hiring a TRAINED Tech.
    • tsbservice
      Field tech
      • 8020
      Wrong forum.
      Phil is right.
      As for calling toners inks, it would be nearly impossible to guide you with such a knowledge.
      • jemmanuil
        • Apr 2020
        • 3
        If you intend on servicing this yourself ( not recommended ) you better buy/locate a service manual.
        What happens in you open that door? Does the message stay the same or does it change.
        I would recommend hiring a trained tech.
        i tried opening and closing the door many times as well as turning off and on the power of the photocopier but the annoying message is there still.
          • 37520
          As tsbservice said "wrong forum."
          The Newbie Check In forum is intended for what its name indicates, New Members checking in so that we have a chance to get to know a little about you, or at least you are here and have the intelligence to understand that this is not where you post problems and questions. There is a Technical Forum for the make MFP in question. Use it. All techs who work on that make and model will then get to see your post and might be able to help you.
          • bob marley
            • Jan 2012
            • 1339
            There is a Technical Forum for the make MFP in question. Use it. .
            ( https://www.copytechnet.com/forums/konica-minolta/ )
            Live for yourself and you will live in vain. Live for others, and you will live again
            • LOVABOY
              • Nov 2024
              • 5
              I own a konica minolta bizhub c458 brand new copier. The first time i turned it on it showed a little arrow on the screen indicating that the component door just under the bypass tray is open. However, this door is closed. I tried turning on and off many times but the message persists.
              What can i do?
              • LOVABOY
                • Nov 2024
                • 5
                IMG-20241125-WA0033.jpg Screenshot_20241126-035837.jpg good morning
                • LOVABOY
                  • Nov 2024
                  • 5
                  Hello
                  • copier tech
                    • 8165
                    Originally posted by LOVABOY
                    Check the sensor & actuator that detects when the door is open.
                    Surprised you found a new C458 this is a discontinued model now.
                    • copier tech
                      • 8165
                      Also check the loom that connects the main machine to the lower paper deck this could have got damaged during transport.
                      • LOVABOY
                        • Nov 2024
                        • 5
                        please, where on the machine can i find the sensor?
                        • LOVABOY
                          • Nov 2024
                          • 5
                          good morning
                            • 23008
                            It sounds to me like you're going to need some help with this problem. Experienced service techs are available in your area. =^..^=
                            • femaster
                              • May 2011
                              • 1509
                              What can i do?
                              Just to give you a helping hand, this is the "Newbie Check-in" area, designed for new users to post about themselves. You are unlikely to get very many responses in this area since this is not the area for technical questions / problems. Start a NEW topic here:
                              https://www.copytechnet.com/forum/te...konica-minolta
