sharp AR-M450N (error code f1-15)
  • JMENDOZA@NEVILLSOLUTIONS
    • May 2025
    tryed sim 14 to reset. finisher is out of service
  • OMD-227
    You have a finisher exit tray trouble code.
    Do you have the saddle finisher (left side) or standard finisher (right side)?
    Check the finisher exit trays are straight, connecting plates are not bent and there is obviously nothing underneath them. You have a problem with either the lift motor assembly, lift motor, exit tray position sensors or bent connecting plates for the exit tray.
    Run the lift motor test in sim 3 as well.
      • 22927
      AR-FN7 or AR-FN6?
        its a saddle finisher
          • 22927
          It's an AR-FN7.
          The customer bends the exit tray brackets when moving the copier. Upper limit switch is actuated before the tray height sensor. Reform the exit tray brackets. Extend the actuator on the exit tray if necessary. =^..^=
            It's an AR-FN7.
            thank you. customer moved machine and bent the brackets. replaced brackets working fine.
