Database Errors
    • 22985
    Database Errors
    There are a few threads I would have liked to respond to, but I haven't been as fortunate as some of you in posting. I'll keep watching, for when Copytechnet is working properly again. =^..^=
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: Database Errors
    Database error. How to reply to a thread.
    1. Logout of CTN (view in guest mode)
    2. Select the thread via the normal "reply post". (Bottom right of the thread page.)
    3. Login when prompted by CTN.
    4. Type out your message as normal
    5. Click "Submit Reply" as normal.
    6. Logout (view as guest).
    repeat steps 1..6 for each interactive thread...
    • roho
      • Mar 2009
      • 844
      Re: Database Errors
      Thanks, that actually worked, have been having data errors for days.
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5777
        Re: Database Errors
        why cant they just fix the website?
        this is BS.
        im out...
        • monarke4
          • Oct 2018
          • 185
          Re: Database Errors
          this is BS.
          im out...
          It's possible that the administrator "Aneurysm" cannot access his account to rectify the problem (if indeed the problem is hacking. It could be he is out of town (like many people) for the upcoming Thanksgiving Holiday He is trying to fix the problem but it is much bigger (a problem with vBulletin software) than he could possibly anticipate etc.
          • Zaxxon
            • 608
            Re: Database Errors
            My guess is the messing up is self accomplished, update or plugin went bad. Seen several times on this forum. Admin will always have access to the database/files through the webhotel support. Hope it will be sorted out soon, keep up the good work admin
            Please start you post with brand, model, problem.
            • monarke4
              • Oct 2018
              • 185
              Re: Database Errors
              I find it a little odd that admin's profile indicates he has not been logged on in 6 days. Unless of course most of the administrative duties do not require one actually logging onto the board.
                • 22985
                Re: Database Errors
                I really hope that I'm wrong, but this may be the dead knell of Copytechnet. I've participated in 6 other forums over the years ... all of which are now gone.
                My suggestion is that you might update your addressbook of members while you still can. =^..^=
                • tsbservice
                  Field tech
                  • 7951
                  Re: Database Errors
                  this is BS.
                  im out...
                  I just hope they(Admins) are healthy and at light side of 'The Force'.
                  Otherwise you are absolutely right, they better fix this inconvenience or will loose their major Contributor.
                  • dan7777
                    • Dec 2012
                    • 680
                    Re: Database Errors
                    Thanks for that! I thought they kicked me and Phil off! No big deal for me. I am just waiting for a service call which I doubt I will get except for emergency on day before Thanksgiving. I was able to respond with your help to a post.
                    • Aneurysm
                      Administrator
                      • Jan 2005
                      • 1030
                      Re: Database Errors
                      I'll be working on it over the long weekend, not sure what the heck is going on, If tried the usual database clean-up which is getting hung on some bad data so if I can't get it working reliably soon I will be bringing in some "professional services", AKA paid support to work on the database. I guess after 610k post it's due for some upkeep.
                      Wish me (us) luck
                      • Aneurysm
                        Administrator
                        • Jan 2005
                        • 1030
                        Re: Database Errors
                        Wish me (us) luck
                        OK I found something, working much better for me now, how is it on everyone else's end?
                        • Blizzoo
                          • Aug 2013
                          • 604
                          Re: Database Errors
                          Mine is OK now, thank you!
                          • 907tec
                            • 434
                            Re: Database Errors
                            Able to view/post again! Thanks for your work, Aneurysm.
                            • JR2ALTA
                              • Feb 2010
                              • 2030
                              Re: Database Errors
                              "Much better" not applicable.
                              Definitely a BREAK/FIX scenario...thanks much!
