Search Function Broken?
  • femaster
    • May 2011
    • 1527
    The search functionality in the forums seems to be broken. When attempting to search (in the Konica group at least), the results are just a bunch of random threads that have nothing to do with the search term entered into the search box. The results also don't look like they used to. There seems to be an error in the code used in the search function resulting in extraneous data being included in the search terms (keyword) that then provides garbage results. In the example below, the search term was "blinking", yet part of the code is showing up as an additional search term ("forum:40"). See attached image.
    • 23010
    Re: Search Function Broken?
    In the interim you can use Google, phrased like this:
    site:www.coptechnet.com konica minolta C2557
    (for example). Works great. =^..^=
    • tsbservice
      Field tech
      • 8076
      Seems to work for me atm.
        • 37641
        [ATTACH=CONFIG]55704[/ATTACH]
        What I have noticed is that that layout has changed. No longer seeing the option at the top to select the forum to search and no longer to select a specific post within a thread.
        • Gift
          • Mar 2011
          • 2459
          Originally posted by selena_homes
          try a new account
          lol - go for it slimslob^^
            • 37641
            try a new account
            You need to read the Forum Rules.
            General Rule 1. Each member is allowed one login account. Registering with multiple accounts is not allowed.
              I doubt "it" will, I think selena_homes is a bot.
                • 37641
                I have a feeling that part of the problem is that according to the software information at the bottom of page the site is using vBulletin version 4.2.5 which is m=not fully compatible with PHP 7.2.0 or higher. The latest stable release is vBulletin version 5.7.1 as of August this year. version 5.7.2 is currently being tested.
                • tsbservice
                  Field tech
                  • 8076
                  Of course it's, I can almost smell them no crystal ball needed 🤣
                  • ctuinstra
                    • Apr 2011
                    • 49
                    [ATTACH=CONFIG]55688[/ATTACH]
                    I've had this same issue for some time now. Makes this forum almost worthless trying to see if there is an answer out there. And, there is no real answer to this issue apparently.
                    • tomcatt
                      • Jul 2010
                      • 93
                      I have had better luck doing a search on the main page and not in the particular forum
