Tips for Techs
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Tips for Techs
    In an effort to help others and get my knowledge expanded, I thought to start this. It occured to me as I watched a tech struggling to put on a corona wire. It kept popping off leaving him to crawel around looking for the spring. On his fifth try, I walked over and laid a paper towel over the corona channel and when it popped off again, it stayed in the channel. I know every tech with years on him or her, has tons of stuff that could be shared, like using toner to power drum blades, or how car wax will help fix old glass on analog machines. I think if we think hard we can all remember some good ones.
    1. Cover coronas when putting new wire in.
    2. Wax old glass on analogs to help with stop position.
    3. Do not vacuum out Konica DV boxes
    4. Carry spare "e" clips in wallet. [ someone posted this last week]
    5. Before unplugging all the wires on a board, look to make sure there if there are unused connectors, it can save you some confusion when putting it back together.
    In other words the kind of things you find yourself schooling new hires on.
  • Wild Bill
    • Jul 2005
    • 774
    If you loose your spring hook, get a large paper clip and take your needle nose pliers and create a loop at the end. Works great! I had a swing plate to replace on a HP 4250 and I used it to remove the spring on the little plastic toner cartridge guide. That big spring came right off!
    Izzy
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I started this thinking I would get a lot of info but nobody wants to play
      • bojans
        • 1313
        1.Always bring original paper A4, A3 (Letter, Lodger) with you, which can compare with customers paper.
        Many of my customers cut paper. And it's not always perfect size...
        When you get too many strange jams go to 1.
          • 23010
          I've been thinking, but most of my experience is situation specific. General suggestions don't work in all situations.
          I think its good to be flexible when you're out on calls. If you always do this, or always do that, there's no room to make that intuitive leap, right to a simple solution.
          General suggestions?
          1) Wait. Try not to figure out the call in advance, before you get there. It can put you in the wrong train of thought, making you blind to a simple answer.
          2) Listen to the enduser, and ask lots of questions. They have many more clues than you do, and often take some prompting to reveal them. I understand that much of what they say are false conclusions or speculation. It's your job to sort that out.
          3) Observe before you start doing things to the machine. That pile of toner in the front door may have a lot to do with what you're there to fix. If you just vacuum it up and move on you just made your problem more difficult to solve. Don't ignore that loud grinding noise.
          4) Fix. Diagnosing the problem isn't enough. Can you make the machine work better in anticipation of part arrival?
          5) Test. Confirm that you you resolved the customers problem, and any problem you discovered too. You may have to back up a few steps to again listen and observe some more.
          6) Document your solution. Don't count on remembering the solution 5 years later. After many years in the business you'll forget much more than you can remember. Excel never forgets, recalls all the details, and can be searched by keyword. My memory doesn't work that way. It needs some prompting.
          And don't hesitate to treat each situation differently. =^..^=
          • bilyahn
            • Dec 2006
            • 1470
            Blackcat how do you have your Excel program setup? I would love to have a template or an idea of how to setup a database like this for our company. I can barely remember some of the fixes I did last week much less 5 years ago, especially if they were something off the wall. Or I will remember the problem but not the fix!!!
            Thanks for the suggestions on service calls. I believe the biggest tip is to take your time! We all have schedules and time limits but sometimes you need to slow down and follow the steps like blackcat suggests.
              • 23010
              Database
              I am sure that I will regret this, but here it is.
              I've attached the template for the Excel database. I have only one request. When you add a record to the worksheet also paste it to the New Additions worksheet. Once in a while post the New Additions worksheet to this thread and clear the New Additions worksheet. Zip the file and it will attach just fine.
              For the database to be effective it needs a couple things:
              Jam records should list jam codes.
              Error Code records should list the error code.
              Honesty is the best policy here. If it's your own fault, say so. If it's not resolved, mark Unresolved.
              Excel functions best when there are less than 255 characters (including spaces) per cell. It sometimes takes some creative editing to make it all fit.
              If you're concerned about anonymity, use only usernames in the source column.
              Include as much detail as possible. The details of any individual call fade in my memory very quickly.
              You Canon guys will recognize the coding. It hasn't changed in a very long time. I've made some minor adjustments to accommodate changes in technology.
              Enjoy! =^..^=
              • jamesyboy
                toner monkey
                • Jul 2010
                • 188
                I think this is al a good idea top tips!
                I always mark unused connectors on boards with a felt tip before removing the board saves confusion!!
                Carry good calibration charts from a showroom machine they can be used to pull back a customersmachine
                this could get a big subject and help a lot of people
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  here is an oldie but a goodie. I was at a funeral home, an hour away, on a Friday. The machine was an old Minolta 1080 with void streaks. Has trashy developer, and the guy needs it to run that day. Hmm... how to filter crap out of developer? I ask the mortician if he had any ladies stockings. Sure we do, he said, we use them on the corpses. I poured the developer through the stockings and successfully got the trash out.
                  • fixthecopier
                    ALIEN OVERLORD
                    • 4713
                    Here is a tip for anybody who gets to work on shredders. Unlike a copier board, that is usually put together in such a way as to make it nearly impossible to plug in the wrong wire to the connector, a shredder will have a whole row of 2 prong connectors and all the wires are the same color. Draw yourself a map before unplugging anything. I blew a $2400 shredder to learn that.
                    Also, a lot of shredders that have oil tanks, have the tanks wired to the door switch. Machine will not run, and says the door is open, it may just be low on oil.
                    • minimerlin
                      • 851
                      I tend to just take a few pictures with my PDA camera, also useful if you are about to strip down a drive system for the first time.
                      Please do not PM me without asking first.
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        I keep a digital camera with me, however almost all of the military buildings I work do not allow cameras or phones. I have had a photo save my ass a couple of times in the shop. I am afraid I will forget one day and pull my camera out in the wrong place, and , well, you may not hear from me for a while.
                        With that in mind, I could start a thread about the most embarrassed you have ever been on a service call.
                        Every section of the military has a "Command Center". This is usually a large room with giant flat screen tv 's on the wall and rows of computers and red phones. I had gone to one to look at a shredder. Outside the door was a table where you were supposed to leave your phone before walking in. I put my phone there and went in to check the shredder. There was nothing going on and only 4 or 5 people in the room. When I left, I forgot to pick up my phone and did not notice til I got home. I went back next morning and reclaimed my phone. Later that week my shop called and said I did not write down the serial number on my ticket for the shredder. I called the point of contact and had him meet me at the Command Center so I could get it. I was just going in for a minute and decided to keep my phone in my pocket. When he opened the door, the room was full of people and 3 of these giant screens were on, each one showing another command center at another base, all full of people, as they were having some huge meeting. I hesitated to walk in, but the sergeant said it was o.k., the meeting was not classified, just be quiet. As I walked through, I must have been at the exact center of the room when my phone started to ring! People at 3 other bases and the room I was in, all said or yelled "WHO THE HELL HAS A PHONE IN HERE?" I have this blurred memory of me grabbing my back pocket where the phone was and shrieking like a little girl as I ran for the door. I think I made up a serial number to close out the call, as I would not go back in.
                        • rthonpm
                          • Aug 2007
                          • 2859
                          Here's one I learned the hard way: don't always trust the model on the front of the machine. Check the labal on the back or frame with the model and serial number. I ended up eating an LD 232c controller ordered down because someone put a 232c sticker on an LD 228c, which uses a different board.
                          • jonhiker
                            • 661
                            A sharpie can save the day.
                            Also, patience is very important. The most important call is the one you are on. We've all been in the situation with several calls waiting, some are down, etc.. mistakes happen when you lose focus on the machine in front of you.
                            Your fellow techs are a good resource.
                            • dickierock
                              • 252
                              camera phone to take picture of connections on main boards you are not familiar with before stripping down,
                              tipex useful for marking units when swapping units/boards around for quick fault finding,also to mark rollers/motors to check if they have moved when you cant visually see yourself,
                              a fuser rebulid will take 15 minutes if you take your time,it'll take twenty if you rush..
                              gluegun,bradawl,assorted screws n clips,theres nothing that cant be fixed!!
