Canned Air!!!!
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Canned Air!!!!
    Just want to check. Are most dealers using canned air? If so, what brand are you using and what price are you paying? Ames AQS Air 15 oz. can runs $9.00 per can when you buy it by the case. Looking for an alternative... Of course it has to be Non-Flamable. We tried one that turned into a blow torch. Don't want to do that again.
    My mission here on Earth is to help all you Dum-Dums!
  • JustManuals
    • Jan 2006
    • 9838
    I buy 10 oz. cans of Falcon Dust-Off at 3 for $9.99 at microcenter.
    HtH
    Paul@justmanuals.com
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      We just use a manually operated blower brush (without the brush extension).
      • JustManuals
        • Jan 2006
        • 9838
        Daz.......You oughta join the 21st century.
        • Cipher
          • May 2006
          • 1309
          Coca-Cola admits that Dasani is nothing but bottled tap water.
          And in another shocking story
          Cans of compressed air is nothing but............................ air.
          Blah the 21st century blows LOL.
          • JustManuals
            • Jan 2006
            • 9838
            'Blah the 21st century blows'
            Well, ya got that right!
            • just a tech
              • Jan 2007
              • 332
              hey daz.. i use the best of both worlds... an air can and a small paint brush..
              • ZOOTECH
                Senior member of CRS
                • 3375
                Just don't use a vacuum with the spray can, I had one that 'backfired' on me, scared the pi$$ out of me (glad I wasn't at customers). Not sure if spray was non-flammable or not, but the static buildup of the moving air might have done it.
                • DadO
                  • Dec 2007
                  • 404
                  I, like u all don't understand why are pressured air so expensive, Its a dam air, not hydrogen bomb....
                  I never tried but will, to buy a air compressor and "rechargeable" pressure cans.Of course, its a bomb if u try to manually recharge can ...if u don't use appropriate tools.This is an unconfirmed idea
                  I will send a e-mail to "jackass" for testing
                  • lkrsardis
                    • Dec 2007
                    • 316
                    canned air
                    We had a tech blow the front door clean off its hinges on a NP 6545 one time.
                    That was a blast. He was using compuserve air.
                    Like the United States Postal Service It's a miracle it works!
                    • dogsbody
                      • Jun 2007
                      • 289
                      only use my mark 1 blower brush now, a year or two ago over my christmas leave the car was sitting for about a week, temperature outside got to about 42 degrees (about 107 farenheiht), a can of air was in my tool box and it blew the side right out of it. Haven't touched it since.
                      The force will be with you always.
                      • DadO
                        • Dec 2007
                        • 404
                        Hahahah u say a blast? Luck is, i never experienced simmilar (cans blowing up, limbs going off ) but did saw few examples what u should not do whit an can, still didn't repelled me from idea of compressor and a
                        rechargeable can at least until accident don't happen
                        • euro scott
                          • 127
                          i had to ban it from the shop for a while as a had a shop tech that was huffing it and getting stoned..when i finally found the one , hes now in a different line of work
                          • yourownfree
                            • Dec 2007
                            • 474
                            plubbbb
                            canned air is not air, its a gas. I tried to make my own canned air. I took a tire valve and soldered it in the bottom of the can. I then pumped air pressure in it with a tire pump. It's only good for about one squirt. waste of time. you need something thats of heavier metal to put more pressure in. We get about 4 cans of air at Costco for about 10-12 bucks. Hey the canned air thing i made might work if i had a heavier tank and a mini compressor in my tool case.
                            too much weight. just need a screwdriver and do air blowing exercises daily, to keep your lungs at top notch air force potential. Ever tried blowing air from your mouth to clean a part off, it seems to go back in you mouth for some reason, never do it anymore, too many germs and crap stuck in the dust. End up coughing for an hour trying to get the dust bunny out of my throat.
                            • lkrsardis
                              • Dec 2007
                              • 316
                              This blows
                              Toner snot at the end of the day.
