Kyocera products scan to email no SSL
  • toddanderson
    • Dec 2005
    • 238
    KyoceraMita does not use SSL for sending email.
    Has anyone used any free email servers to relay mail to yahoo,gmail,hotmail
    I have tried several free email servers with no luck.
  • 10871087
    • Jan 2005
    • 1062
    I have used Agrosoft in the past but can't say I have tried using it to do what your trying to do. give it a shot, it has bailed me out many times in the past and the price is right!
    ArGoSoft Mail Server
    • toddanderson
      • Dec 2005
      • 238
      Thank you
      Yes i have tried argosoft and many others , but i have not had any luck
      getting scan to email to work on the kyocera products, to hotmail,gmail, yahoo
      • tmaged
        Owner/Service Manager
        • 1896
        From what I was told, under the security link at the bottom of the Falcon III's & the Taskalfa's, when you enable security here it is SSL no matter what the protocol you're using. I've got 1 Kyocera and 2 Sharp machines that all are using SSL SMTP connections & I cannot get any of the three to work. Anyone have any ideas ??
        One Sharp & the Kyocera are using att.yahoo for SSL SMTP and I can't get it !!!
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • printerman
          argosoft
          I have a customer with a KM-C3232E, I was able to get them to scan to email with argosoft but there seems to be a size limitation. Any suggestions on something else to use or how to change the size limitation?
          • Jules Winfield
            • Jul 2009
            • 821
            I've used Argosoft in the past and it works great for most scenarios. Recently I discovered a new mail server app that has a free version like Argosoft, but has way more features. I needed something that could import a list of user accounts from a CSV file (something Argosoft can't do) and I found this:
            DeskNow
            But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
            • n25an
              • 1030
              go into the scanner then to send email settings then to basic settings and set the scanner to data size non restricted...
              if it doesn't take then use the address editor...
              if the settings take but you have the same size issue... then your email account that is connected to the copier has a size restriction setting that your client or their email provider must adjust...
              Sad To Say I Don't Have a Life
              I do this stuff on the weekends too
              • n25an
                • 1030
                aim mail
                I have found aim to be the most reliable...
                • toddanderson
                  • Dec 2005
                  • 238
                  aim ?
                  What is aim ?
                  • n25an
                    • 1030
                    email...
                    What is aim ?
                    webmail.aol.com
                    I use email accounts from aim mail all the time...
                    • jneezy2008
                      Software/IT
                      • Mar 2009
                      • 72
                      I recently found Gawab.com Web-based Email email POP3 SMTP IMAP SMS. You just register for a free account and use the SMTP settings to setup scan to email. It's 100% free. You can use SSL if you want, it's optional. As long as the account is kept active scan to email will work forever. There's nothing to install or setup on a customer's PC. I've tested Gawab.com Web-based Email email POP3 SMTP IMAP SMS on several of our showroom MFPs and it has worked everytime.
                      The snozberries taste like snozberries!!
                      • tmaged
                        • 1896
                        Yo JNeez, I set up an account that seems to work, but I never get the emails. I've tried it going to a couple accounts. Is there anything I'm missing ? I'm using 66.220.20.53 as the mail server. It goes through so I assume authentication is good & we're getting a handshake that the mail is complete. When I check the job log, it shows it went OK. Any Ideas ?
                        Thanks,
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          I've had really good luck with GMX.
                          Free Webmail and E-Mail by GMX | Sign Up Now!
                          It's webmail, but has an SMTP component as well.
                          So far, so good.
                          • jneezy2008
                            Software/IT
                            • Mar 2009
                            • 72
                            tmaged,
                            I would suggest using psmtp.gawab.com instead of the IP address. I just pinged psmtp.gawab.com and got a different IP than what you've posted.
                            Also, check the recipients junk mail folder.
                            • tmaged
                              • 1896
                              I tried the IP address that's associated with that host name. I get the same thing with that one. I've tried it to both my accounts so I know it's not going to a spam folder. I may try the GMX listed above.
                              Isn't there usually going to be an issue of anonymous relaying throgh the end users ISP with someone elses SMTP server ?
                              Thanks for the help.
                              BTW I was told that the Falcon III's, Stratos & Taskalfa's all support SSL SMTP connections by my Kyocera Service Rep.
                              Hope that helps !
                              -Tony
                              www.dtios.com
