Scan to SMB
    Re: Scan to SMB
    From the Guy who has no skill no factory training no certifications. Do you even have a tech id with Kyocera
    It's just embarrassing
    I'm lucky that I know how to make a sandwich. It's a daily struggle to survive.
      • 29799
      #47
      Re: Scan to SMB
      Be sure to wipe the guys pc like the last time
      That will fix it for sure
      • Rewind!
        Somehow it works....
        • Jan 2019
        • 89
        #48
        Re: Scan to SMB
        Just going to add my 2 cents... dependant on the size of the network, backup scripts, and devices there could be replication of certain folders/files on more than 1 computer (I have scripts setup to duplicate files in desktops and documnets folders in case of failures). The above mentioned setup normally requires a running active directory on a domain. There are also "Cloud Based" share drives that could replicate this same issue as there are ulitimately 1 location (i.e google drive, onedrive bussines).
        JC
        • Santander
          • May 2009
          • 768
          #49
          Re: Scan to SMB
          Does Kyocera allow you to setup groups for scanning like Ricoh does? Create the group, create the individual destinations, add the destinations to the group, select the group when scanning.
          Yes you can setup a scan group on a KYO. Kyo also allows you to individually select multiple computers for a scan function without setting up a group.
          • PrintWhisperer
            • Feb 2018
            • 464
            #50
            Re: Scan to SMB
            I ran into a strange occurrence the other day that I'm having a hard time wrapping my mind around. Perhaps some can shine some light on it.
            Here's the strange thing that happened. When I scanned to one of the PC's, the document appeared in the scan folder on the intended destination but also was in the scan folder on a totally different PC.
            Thoughts?
            Billy I don't know if we ever established that this was a Kyocera, but I found something which is a possibilty.
            You may be crazy, but not in this case
            Corrective measures for Broadcast failure when using Send function
            A failure of sending to unintended destinations in broadcast by performing a certain operation while using the send function.
            [Phenomenon/occurrence]
            When closing the job setting screen with [Cancel] key, the setting is retained and it is broadcasted with an unintended destination in the next sending. (Main unit firmware factor)
            (*1) Applicable to broadcast with FAX, Box send, Send to SMB/FTP/E-mail, also same in Accessibility Display
            1. Press [Start] key to send FAX when setting a job for FAX without pressing [OK] key. *
            2. Job setting screen reappears after sending and press [Cancel].
            3. Next destination is set to send with the job setting retained.
            4. Sent with the destination set in above 1.
            *: If pressing [OK] at 1, there is no problem when pressing [Cancel] at 2.
            KDCQA-7638
            2VG-1751
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
              Re: Scan to SMB
              KDCQA-7638
              2VG-1751
              Where in the world did you find that? I did feel like I was going crazy. I can't remember if I closed the job setting screen with the cancel key but I will check it out next time I'm out that way.
              And this is a firmware problem or am I reading that wrong?
              PS - Yes, Kyocera 3551ci
              • tsbservice
                Field tech
                • 7963
                #52
                Re: Scan to SMB
                KDCQA-7638
                2VG-1751
                Reading and understanding bulletins from deeply IT specialized tech imho shows UNICORN. I read and understand what engineer talks about MFPs but usually have no clue what IT guy is asking 🤣
                • calebgk
                  • Jan 2019
                  • 21
                  #53
                  Re: Scan to SMB
                  JC
                  You should definitely check this if you haven't yet. I didn't see any mention of it earlier in the thread. Make sure you aren't fighting the wrong problem, and just find out they have their scan destination included in a synchronized folder library. Google Drive, Box.com, OneDrive.
                  • PrintWhisperer
                    • Feb 2018
                    • 464
                    #54
                    Re: Scan to SMB
                    Well TBH the bulletin is on the 6053ci series v 2.151 firmware dated 10/2020. That doesn't mean it's not possible on earlier models. It wouldn't be the first time I've seen a bug repeated until the generation it is discovered in. Fixes are generally only developed for current production.
                    There is not documentation showing the problem was reported for '1' series though.
                    It is a firmware fix on the '3' but I saw no fix for the '1'. If you can repeat the problem that would be interesting.
                      Re: Scan to SMB
                      It's very interesting. Thanks for sharing. I still agree with your original statement that there's one session for each PC. No?
                        • 37243
                        #56
                        Re: Scan to SMB
                        I am certain that most manufacturers have the same time out options that Ricoh does. Unless the customer requested otherwise, I normally set function timeout to 15 seconds, user timeout to 25 seconds and and machine timeout to power saving mode to 35 seconds.
                        • PrintWhisperer
                          • Feb 2018
                          • 464
                          #57
                          Re: Scan to SMB
                          • J_Arnold
                            IT Director
                            • Sep 2021
                            • 87
                            #58
                            Re: Scan to SMB
                            Okay, I have 2 computers and 1 Kyocera copier as part of this physical lab. I changed the hostname of PC 2 to the same name as PC 1 and a warning popped up telling me that this was a duplicate hostname but it let me change it anyway.
                            I then went to my SOHO router and there are 2 entries for the same hostname but with 2 different IP addresses. I scanned a doc. and it did not go to both PCs.
                            However, at my customer's office I have the same username and password on both PC's and the scan folder is named "scan" on both PC's. Without these being the same on both PC's, it's never gonna scan to both PC's. I'll have to change this also I suppose.
                            Under security did you share with everyone or the Scan user you created? Did you create a local user profile on a PC and name it Scan giving yourself Admin rights. Create a folder and name it scan, then go to properties > Security and add your profile as a source, then go to sharing and allow profile full control. I don't see how this can be shared ( without a server or cloud service)unless they have some type of home-sharing nonsense going on. Have you tried using IP instead of name in the network path? Apologies I have not read the entire thread just brain storming. Last thing I am not trying to be insulting , but you are not using SMB Scan_to_file( public ) are you? This will of course share the file out to anyone with access to the shared folder.
                            “First comes smiles, then lies. Last is gunfire."
                            • tsbservice
                              Field tech
                              • 7963
                              #59
                              Re: Scan to SMB
                              Common brainstorming on multiple pages thread... really?
                              Your points are fully qualified but don't you think folks here already suggested all usual stuff plus.
                              Please excuse me if this sounds like rough welcoming. And by the way Welcome to the forum
                              • J_Arnold
                                IT Director
                                • Sep 2021
                                • 87
                                #60
                                Re: Scan to SMB
                                Appreciate the welcome, but I have finished reading and it sounds like I wasn't far off. And No... I see a lot of over thinking being done. Plus what do you care what the hell I do, or my process by which I do it * shake my f*cking head* , I wasn't answering your question, but thanks....
                                Billy if I offended you by assuming and jumping ahead my apologies sir! Unless they have a network guy and a server and he has been messing around this is a small network or a copier issue...KISS
