Why does wsd printing work then not work?
  • fishleg
    • Mar 2009
    • 426
    Hi, just a quick one when customers add a printer via doing it themselves usually windows will use wsd and do everything. I've seen literally hundreds of instances now and I usually just disable wsd on install to prevent it but still if I forget, a user uses wsd it will work but then suddenly not work without installing the printer again?
  • Gift
    • Mar 2011
    • 2459
    Re: Why does wsd printing work then not work?
    I don't get the question here but we all know WSD is not reliable. We also disable WSD at all new machines since a while during pre-install in our shop.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 694
      I'm not sure "WHY" it doesn't work, but it's quite irritating that it doesn't. I wish it would, as it's a nice way to quickly be able to print... But if it's going to be helpful to connect, at least switch it to IP.
        • 30213
        I love wsd it me make lots of money fixing customers problems
        The main problem it never installs the correct print driver on commercial equipment
          • 23007
          Maybe I've got this wrong. Somebody please correct me if I do: WSD only connects with the printers during initialization. If the printer loses communication, or is not available during bootup of the PC, it won't connect, then stay unconnected. The ONLY time it can connect is during initialization, kinda like the old parallel printers. That's why restarting the PC always fixes WSD connection issues, at least temporarily. What is doesn't do is print those stranded print jobs in the queue that have been sitting there, sometimes for years. Just make WSD go away.
          On a tangent, another thing that I've seen Windows 11 PC's doing is changing IP addresses, default printer choice, even deleting installed print drivers all by itself. There is a toggle switch: "Let Windows manage your printers ... " DEFINITELY choose NO. It makes bad choices.
          • ntbann
            • Jan 2012
            • 628
            We started disabling IPP also as windows will load a printer on that too.
            • mbcruzin
              • Aug 2013
              • 142
              WSD was windows poor attempt to simplify driver installs. I love it when the driver is set up with XPS instead of IPP..... WHO STILL USES XPS??? So we have been doing the same things. Disable WSD/IPP and let the customer know that the OEM driver needs to be installed to get full functionality. However I still have to explain this to IT people that insist on using a universal driver.
              Unnamed IT guy: I have a color printer that will only print BW.
              Me: Did you load the current OEM driver?
              IT guy: no we just installed a universal driver.
              Me: Please load the current OEM driver and try that before you share it out on the network. (Screaming in my head:: HOW ARE YOU IN THIS FIELD AND GET PAID MORE THAN ME!!!!!!!!!)
              • Hart
                • Feb 2024
                • 401
                Why disable IPP ? I currently have no problem with it.
                Sharp now have WSD disabled by default, IPP still enabled.
                You need IPP for AirPrint no ?
                • mbcruzin
                  • Aug 2013
                  • 142
                  Airprint uses Bonjour mainly. Plus I use LPD when setting up most of my Mac drivers. If someone comes to me with a mobile device like an Ipad, then I would turn IPP back on just in case. However most of my customers do not.
                  • copier tech
                    • 8144
                    Yes WSD is so flaky, only really designed for the home user or office staff who bring a laptop into the office occasionally for the odd print.
                    WSD nice idea, shame it's so unreliable.
                    • alp
                      • Jun 2012
                      • 39
                      It was once explained to me by a " highly credentialed" IT person that WSD issues a security cert on install. However that Cert has an expiration, so in time it will stop communicating. Reinstalling the printer will renew the cert. Whether that is true or not, I dont know. I have found no documentation one way or another, but it sort of makes sense.
                      • Mako
                        • Jan 2025
                        • 779
                        Disable WSD and IPP on set up before machines go in the field.
                        • Reybdiel
                          • May 2025
                          • 1
                          Always set a static IP or DHCP reservation for the printer and install it using a Standard TCP/IP port instead of WSD. A stable connection and avoids the reinstallation headache also works.
                          • SenseiNYC
                            Wireless/Network Engineer
                            • Jun 2024
                            • 34
                            WSD is unreliable as it creates a psuedo name entry to address the device as well as a port. it then creates a session to the device however the slightest thing can upset the session and even kill it. When this happens you obviously will have a problem printing. If your network is properly configured and you use the OEM drivers, WSD is simply a waste. I never use the MS drivers, especially I disable the OS' ability to auto-detect new printers.
                            • Hart
                              • Feb 2024
                              • 401
                              But the real question is, what's the best alternative on Windows ?
                              For Mac most of the times I don't bother with driver (unless there is a finisher) and go with the AirPrint solution, but for Windows I have no idea.
                              I have customers that does not have Admin access on their Windows laptop (and IT refuse to do anything about it) and I can't do shit about it, I go with the default Microsoft driver.
