dropping off line
  • LNorris
    • Sep 2008
    • 645
    dropping off line
    Kyoceras.
    i have 2 customers reporting that MFPs are dropping offline. 1 customer has a 2550 and a 3035 doing it and now another customer has called in stating that their TA250 is dropping off line. they can power the machines off and back on and it works. they will work for awhile then the computers will show the printers as being off line.
    anyone else seen this?
  • Ducttape n Glue
    • 195
    Are they plugged to a router? I have seen where routers start to fail and this will happen.
    • LNorris
      • Sep 2008
      • 645
      i believe so, thats where i'm looking right now. seems only certain people are being affected by this. but of course, the IT personnel says its not them or their equipment
      • Ducttape n Glue
        • 195
        Try the individuals computer ports who are failing . Also poorly made cable connections that may get jostled alot. Any changes in the cabling or routing of these individuals also.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Seen this on couple Ricoh models and a Canon with an Axis print server.
          Both were finally fixed when manufacturer came out with firmware updates.
          At the one account this sharp network guy setup a bot to ping the printers every 20 minutes or so and it kept the Ricoh's alive on the network.
          You might try enabling or disabling snmp.
            • 23006
            Dirty AC power can cause Copystar MFPs to drop off the network. The only accurate way to diagnose this is to set up a power quality analyzer with event recording capabilities.
            In each case, when the power was cleaned up the machine consistently stays on the network. =^..^=
            • jewen25
              • Mar 2009
              • 197
              try this goto network setting of your machine try scroll and search the 10/100 and put in "auto"
              ERROR HELP ME AND HELP YOU
              • verderacer
                • May 2008
                • 158
                Few questions for ya first...
                1. Does the copier(s) reside in the same network segment as the worksations?
                2. When the copier(s) go/goes offline is it still pingable from a workstation?
                3. Can the copier(s) ping the local gateway?
                4. Are the workstations printing direct IP or shared through the server?
                answering these questions will determine if its the coper or a network issue...
                Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
                MCSE/CCNE/ENS and other crap...
                • chriscctx
                  • Mar 2010
                  • 37
                  Mine was doing the same thing - I went into printer properties, ports, config ports and unselected the SNMP and it worked fine.
                  Maybe this will work for others as well.
                  • LNorris
                    • Sep 2008
                    • 645
                    update (sorry for taking so long).
                    seems that the entire banks network was going down. affecting all locations and manufacturers of copiers. so it wasnt my machines in the first place (like i told them )
                    • Vulkor
                      • Jun 2009
                      • 946
                      Christ the Banks network was flaking and their IT guys weren't even away of it. FIRED!!!!!!!!!!!!!
                        • 23006
                        It sure is nice to be right once in a while. It's nice when they believe you, too. =^..^=
                        • Stirton.M
                          All things Konica Minolta
                          • Oct 2009
                          • 1804
                          I always enjoy the feeling of satisfaction when I prove to an IT guy that it is their network/phone line that is the problem and not the machine.
                          Of course, this doesn't mean there cannot be a machine problem, but from personal experience, this is rare on the hardware I work with.
                          ---Groucho Marx
                          • AyJayAreDii
                            • Jul 2010
                            • 99
                            I am having the same problems in our print shop but only on K/M C451's. 4 shops on 4 separate networks and 5 M/Cs. all dropping off the network and you have to turn the printer off and on to get them back on the network. Does not happen on any other of the Konicas or Ricohs. Our IT guys are saying it is a machine problem and the manufactures are saying it is a network problem.
                            • Stirton.M
                              • Oct 2009
                              • 1804
                              Ensure your firmware is up to date, R6 is the latest.
                              If there are no power conditioners on the machines, this can sometimes be a contributor, along with sharing power on the same circuit with other devices. The machines are power hogs and should not be sharing the same power circuit, it should be separate.
                              ---Groucho Marx
