Scanning Reduction
  • cmsuto
    • Sep 2011
    • 3
    Scanning Reduction
    As per tittle. For copying it is fine. But when it comes to scan the size will automatically reduce, it can even see the feeder belt at the edge of side of the document. I have tried to do the common setting but failed. Any givers can help me.
    Thanks in advance.
  • kingarthur
    • 1356
    Re: Scanning Reduction
    a make/model might help...then maybe put it in the forum of that particular make...
      • 23008
      On most of the MFPs I see, you can designate the original scan size. When we know what model we'll be able to offer some advice. =^..^=
