Let's see, remanufactured toners? Does that mean taking waste toner and returning it to a usable form? Now I can see it maybe with black and white machines where all you have to do is remove any contaminates such as developer and paper lint. When it comes to color you have an entire new can of worms. Not only do you need to remove contaminates but you also have to separate individual toner particles by color.
Never again will I be apart of a company that uses any aftermarket/refill/etc toner in any 2 part developer system..ever.
It's just not worth the increase in service issues and the decrease in yield of the imaging and related parts.
I'll never forget the absolute stupidity of our then service manager when I was a tech working on ricoh's and the 35/45 cpm POS machines. Some moron decided to AGAIN use NA trading junk ..."Hey these drums, developers and toners cost half as much"..."Yes but they only go half as long and explode in the machine making a big mess that destroys fusers and drive gears"..."Yes but 1/2 the cost! Just look at the savings!"
When Sharp pulled authorization on one of the mega dealers years ago we were handed a few National Accounts and schools. I personally went to one school system and visited each building who let me know they HATED their copiers. After a string of questions it all came down to the changing of toners. Each building had multiple Sharps which had the stupid shutters that had to be pulled to add toner. The non-OEM toners that the dealer supplied would not release the shutter without monkeying about. After the teachers began installing Sharp toners their attitudes towards the copiers completely changed. It wasn't even the toner itself but the cartridge that was not right.
I have tested non-OEM toners over the years and all have EVENTUALLY failed. I've listened to all the testing these companies do and how they have Service Managers from companies with throusands of machines running their products that I can talk to. blah blah blah. I was sucked in again about two years ago trying to increase margins on a school system that beat us down to .0035 locked for 5 years. The toners I tried ran for 6 months without an issue with machines going through several toner per month. Then it all fell apart. Toner related error codes that we had never seen before and crap solids or overtoning. Never again (I've said that before )
I see that here that service engineers don't like remany toners. That is fine, I understand that, using OEM will make less problem as many remany toners are really crap and they coming from China and many countries which don't understand what is quality. I test a lot of them and 90% of them are crap.
We need to know that Canon dont make a toner and OPC's. It is all made in separate companies which make toner toner for remany companies as well. OEM toner or OPC no one can bay, it is just made for OEM but another version are available.
If we talk about copy tubes, YES, this is dangers. Toner can make life of DEV units shorter and OPC as well.
So, picking good toner is very expensive and it need a lot of tests, most remany companies don't want to do it and then problems acure. If we talk about small cartridges as HP505X or 26X, for sure there is good toners which can be used without any problem.
To go back to video which I saw. First, they cannot use OEM toner from OEM tubes as first, they don't have enough toner in tubes and empty cartridge is expensive. They need 15 cartridge to refill 1. Even if they try to do it, toner in tube is mixed with carrier. Carrier need to be in some %, depend of model. So, no way that they use OEM toner, it is just impossible.
Regarding marketing on video, I can bet that Canon will sue them as intellectual property here is broken. They cannot use Canon or OEM on their labels.
If I am someone why will take care about toners for some company, I would ask from them on written that they garanty same quality as OEM and if any problem jump up, they need to pay.
