HY FELLOW TECHS,
On CLC 2620 (114 k copies) i have a constant jamming at the fuser assy. Paper goes thru "Enter" sensor(same pm code) then reach "exit" or LEVER DELIVERY and FB6-3662-000 sensor.
Picasa Web Albums - Dario - PICTs
Lever of exit sensor was broken so i glued it (i know i know...)
Just when it deactivate "enter" sensor machine jams( end of paper is 2-3 cm away from enter sensor).
History of this problem:
I had same thing when sensor(lever) broke but i glued it 2 times and 2 times worked on 60k and 103k.
I ordered new lever and sensor but in the mean time i cant correct problem. I suspected on sensor but if he doues not work machine shows jam even after reseting the machine. I adjusted the sensor liver in
many directions this time but that didnt help this time. Thats to adjust the time that paper reach sensor.
I checked the pins on connector an non was faulty (didnt check sensor cable)
Could it be something else this time?
Upper roller is deformed a little(mybe slight more then little
THX for any help!
THX for any help!
