Removing dot from OPC Drum
  • V-P
    • Apr 2011
    • 679
    [Misc] Removing dot from OPC Drum
    Hi Comrades !
    I have a black dot on the OPC drum of iRAC7055.
    The drum is almost new. I tried to remove it with a cloth with water and dry cloth but nothing.
    I was afraid to use alcohol or other stuff.
    Ideas ????
    Merry Christmas to all !
    V-P
    • 22999
    Re: Removing dot from OPC Drum
    As long as you don't scrub too hard, there are a lot of things (chemically) that you can use. In the order of effectiveness:
    Dispersant
    Paraffin Lamp Oil
    Orange Oil based degreasers
    Alcohol
    Dispersant and Lamp Oil, can attack the neoprene of the drum cleaning blade. In any case, you'll want to remove the drum from the cleaning unit before doing any cleaning. Then rinse away the oily cleaners with alcohol. Re-prime the cleaning blade.
    The first few images may have washed out areas, but the cleaning blade acts as a squeegee, removing any remaining chemical residue.
    • teckat
      • 16083
      Originally posted by V-P
      Hi Comrades !
      Ideas ????
      V-P
      Use a cue tip with small amt of "Goo Gone
      Let it sit on spot for 10-15 min
      Then try to remove with a dry cue tip.
      • montana
        • Aug 2008
        • 393
        Hi Comrades !
        Ideas ????
        V-P
        hi...i suggest use apiece of cloth dampened with kyrosene...good luck
        • mramlawi
          • Jul 2011
          • 838
          I used (Silvo) its a liquid small bottle used to clean silvers the drums looks perfect and all the spots cleaned ,also you can use car polish called as i remember (formula1)
          Distinguished road makes you jewel in rough
          • copyman
            Owner / Technician
            • Sep 2005
            • 4632
            If you are sure it isn't a knick then alcohol and soft cloth should be fine. If it is a knick there isn't anything you can do about it.
            • V-P
              • Apr 2011
              • 679
              Thnx guys !
              V-P
