we have never seen this before on these machines, but sporadically the machine will print all the drum colors in solid bars in uniform sequence across the page. cannot find any information in our service manual or records. has anyone seen this before and/or know what we can do to remedy the situation. thank you
Canon mf8350cdn ymck uniform bars across page
Re: Canon mf8350cdn ymck uniform bars across page
U mean like a PG 10 test print, or a Auto Gradation test Page_?**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I've had a Kyocera do exactly this. It had a broken yellow developing spacer, and the yellow mag roller was shorting to the drum. Something like this?:
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
I don't suppose that might be what the machine prints on the transfer belt during the automatic color density and alignment adjustments?
Probably not, those are usually bars of repeating patterns and colors.Comment
it is more similar to the bottom set of samples on the attachment. happens only sporadically. the cartridges are all in one on these machines. going out there today will get the samples from the actual machine.Comment
hopefully someone did not activate "Canon Counterfeit Protection"
different on all Canon Color Products ( color lines, color boxes, puppy tracks single color, background all over page ) seen many variations**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
if it like the bottom one in blackcats sample pic, that could be the ends of the drums getting worn down and grounding out causing the voltage to drop, thus printing color bars of the drum that is grounding out across the pageAccidents don't just happen. They must be carelessly planned.Comment
That's exactly what we found and suspected ...the black drum unit has a gouge to the core on one of the ends ...so we suspected this maybe the culprit ...we swapped out the drum unit yesterday so lets see what happens ....thanks everyone for your help ...
we really appreciate all the input ....
MauriceComment
