Canon mf8350cdn ymck uniform bars across page
  • Intone
    • Apr 2015
    • 68
    [CQ] Canon mf8350cdn ymck uniform bars across page
    we have never seen this before on these machines, but sporadically the machine will print all the drum colors in solid bars in uniform sequence across the page. cannot find any information in our service manual or records. has anyone seen this before and/or know what we can do to remedy the situation. thank you
  • charm5496
    • 2387
    Re: Canon mf8350cdn ymck uniform bars across page
    do you have a sample of the issue you can post for us to see possibly?
      • 16083
      U mean like a PG 10 test print, or a Auto Gradation test Page_?
        • 22999
        I've had a Kyocera do exactly this. It had a broken yellow developing spacer, and the yellow mag roller was shorting to the drum. Something like this?:
        • Iowatech
          Not a service manager
          • 3930
          I don't suppose that might be what the machine prints on the transfer belt during the automatic color density and alignment adjustments?
          Probably not, those are usually bars of repeating patterns and colors.
          • Intone
            • Apr 2015
            • 68
            it is more similar to the bottom set of samples on the attachment. happens only sporadically. the cartridges are all in one on these machines. going out there today will get the samples from the actual machine.
              • 16083
              hopefully someone did not activate "Canon Counterfeit Protection"
              different on all Canon Color Products ( color lines, color boxes, puppy tracks single color, background all over page ) seen many variations
              • charm5496
                • 2387
                if it like the bottom one in blackcats sample pic, that could be the ends of the drums getting worn down and grounding out causing the voltage to drop, thus printing color bars of the drum that is grounding out across the page
                • Intone
                  • Apr 2015
                  • 68
                  That's exactly what we found and suspected ...the black drum unit has a gouge to the core on one of the ends ...so we suspected this maybe the culprit ...we swapped out the drum unit yesterday so lets see what happens ....thanks everyone for your help ...
                  we really appreciate all the input ....
                  Maurice
