Hello guys,
Need ur expert advise on my problem.IR6000 image too light and partially missing(front part).Had clean primary charging unit,drum blade,pre-transfer unit,separation unit still same.Had even change the pre-transfer charging wire. My machine are refurbish type with total counter of 1109000 pages.
Could it be due to drum life or developing toner problem as i havent change the drum or refill the developing toner since day 1 ? Fyi, i've run well untill around 950000 pages(replaced wire & blade once)..it starts to problem when just power on,after warm up & print ~50 pages it is ok.....NOW.....i cant get it print as normal...Pls help!!!
