3045 not fusing toner
  • repeatcopiers
    • Sep 2008
    • 591
    I have a 3045 in the field with only 54k copies on it that is kicking my butt! When we run about 40 test patterns the toner will start wiping off the paper. We replaced the fuser unit, but that didn't change anything. If you just copy a standard letter or something without a lot of prints or images it runs fine. Any ideas?
  • copier tech
    • 8176
    Re: 3045 not fusing toner
    Genuine Canon toner? Humid environment? Paper weight set correctly?
    • repeatcopiers
      • Sep 2008
      • 591
      Yes OEM toner, even vacuumed out the developer and started fresh with OEM toner just in case. Not humid and yes paper weight is correct.
      • Dark Helmet
        • May 2009
        • 856
        Far from a Canon tech but whats your line voltage when the machine is running? I had a Sharp popping low heat codes. Customers power would drop to 108 volts and neutral to ground would crank around 8 volts.
        Fuser was a bloody mess inside.
        • Rachid.Akli
          • Oct 2011
          • 595
          NIP-CHECK and verify if it is correct. If not, the film and the pressure roller are not comming in contact. Have a look on the door closing system.
          Rachid
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • repeatcopiers
            • Sep 2008
            • 591
            Rachid
            The temperature stays at about 220 during the copying process. When we did the NIP-CHECK, nothing happened at all, no NG or OK?
            The door closure seems to be working properly.
            • copier tech
              • 8176
              A nip check will feed a sheet of paper, stop it momentarily in the fuser then feed it out. You then measure the pressure NIP.
              Load paper in the stack feed. nip check will only feed from that paper source.
              Refer to the service manual.
              • Brian8506
                • 1665
                Try raising temp. Copier/option/body/fix-temp. Range is 0-7
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4724
                  Like other poster mentioned look at door closure. I believe there is a lever that when door closes it puts pressure on fuser rollers. I also had to raise temp even with new fusers.
                  • Brian8506
                    • 1665
                    There is a white lever on the left when you open the door that applies pressure when you close the door and releases pressure when you open it. And if that was not working every copy would smear.
                    • repeatcopiers
                      • Sep 2008
                      • 591
                      Thank you, increasing the temp to 7 seemed to fix the problem. We did close the white pressure lever manually before closing the door to check that, but it didn't fix anything, but raising the temp did. Thanks so much for your help.
                      • dan7777
                        • Dec 2012
                        • 680
                        I have had a two 2525's do the same thing. Increasing the temp was the only fix.
