iR-3300 background
  • aAandy
    • Apr 2012
    • 370
    [CQ] iR-3300 background
    Hello everywon
    getting dark background on prints (looks like overtoning, but this is a monocomponent machine) & super solid yet crisp & sharp blacks, tried adjusting density (DE-DC & DE-OFST) in service mode but no matter which combination of voltages i used, the only way i could get rid of the background resulted in the image becoming very faint. DENS-ADJ didn't seem to make any difference at all
    as far as i know the machine has OEM drum & toner & all the settings were as per the front door sheet
    the machine has done 846k prints so i have no idea how old the drum is and i suspect replacing the drum may resolve the issue, however surely i should be able to get rid of the background and keep the nice solid blacks?
    maybe i should play around with primary charge adjustments?
    anyone got any tips please & thank you
  • Tonersniffer
    • Nov 2012
    • 74
    Re: iR-3300 background
    "i suspect replacing the drum may resolve the issue"
    I suspect your right.
    Replace the drum. Why take a machine out of specs for a supply item?
    Copier 101
    • copier tech
      • 8174
      At that count i'd also suspect the dev unit, the spacers wear down resulting in the dv roller becoming slightly closer to the drum.
      Usually when the drum wears you get thin black lines on the prints. (assuming you machine has a genuine Canon drum unit fitted)
      • markyj
        • Jan 2016
        • 7
        I'd start with a genuine Canon drum and toner.
          • 23009
          aAndy, do you know that this machine is 16 years old? Are there any parts available?
          Sic the salesmen on them. When they trade it in you can dig a hole in the yard and bury it. =^..^=
          • aAandy
            • Apr 2012
            • 370
            client wants it fixed, i fix it - it got a new fuser pressure roller, a new drum unit sorted out the background & a couple hours cleaning the thing
            one of these days i wanna push an old clunker off a 4 storey building with cameras everywhere to video it
            • aAandy
              • Apr 2012
              • 370
              thanks everyone for the responses - new drum unit sorted it out and it only cost $125.00
                was it oem ? at that price sounds like after market... did you do gamma adjust?
                  I noticed one of your other posts.... you ended the title in the word " Print " when you do that it prevents us from replying to that post.... it was in reference to a Canon Inkjet Printer not putting print on the page.. you might want to go back and see if you can edit the title for the post.
