IRadv6065 streaking
  • digicor
    • Jul 2008
    • 1159
    IRadv6065 streaking
    I had just went through this machine before delivery, no lines or streaking, after delivery there seams to be some streaking in the print, i advised the client to run it for a few days to see if the streaking would clear itself up, the machine has 700k on it, would the scaper sheet be advised in this case, the fuser roller film was replaced at 549k,
    thanks for any input
  • Brian8506
    • 1667
    Re: IRadv6065 streaking
    Could be drum cleaning blade
    • JParker
      Technician II
      • Jul 2015
      • 51
      If not the drum cleaning blade, perhaps potential control sensor got dirty. Can disable it through service mode to verify.
      • roho
        • Mar 2009
        • 844
        Could be many things, describe the streaks, are they basically in thr paper feed direction, or more like random blobs? Have you cleaned the coronas, is there a mark on the ETB?
        • roho
          • Mar 2009
          • 844
          No film on this device, you can check the fuser rollers visually.
          • lilleputte
            • Jan 2013
            • 153
            Try this
            COPIER > FUNCTION > MISC-P -> DV-RT.
            Caution
            If using frequently, deterioration of developer or toner scattering
            might occur.
            • Cipher
              It's not easy being green
              • May 2006
              • 1309
              Can you get a decent sample print scanned and posted?
              • digicor
                • Jul 2008
                • 1159
                i will get a sample, as of right now the client has not re responded after i told him to run around 100-200
