iR2020 ... For Connecticopy Kent
    • 23008
    thanks for your time n trouble so far. one last request, if you please. i've been in the business since 83, and i'm semi retired, down to 3 or 4 customers. i don't ask for help often, last time i was able to access smarka. i was replacing fuser film on a canon
    ir 2020, and mispositioned 110vac junction plate in fuser, which blew main 15a fuse. i replaced fuse, got a false exit jam when i powered up. i did a hard reset, to no avail. i then repl fuser exit sensor, thinking it was close to the short circuit. i don't have manual, and i'm sure i'm not the first to do this. copier has been down since sept 4. i've reregistered twice, w ith no email sent to alllow me to post here. i've sent aneurysm 2 private messages, no answer. only other forum i can find is asay's "the copier network", which is not as active as this. would you please post this for me? it's asking a lot from out of the blue, but desperate times....what else can i do? thanks again for your time
    Can anybody help this gentleman?
    Sorry that I can't help personally. I haven't worked on Canons regularly since ~2005. =^..^=
  • aAandy
    • Apr 2012
    • 370
    Re: iR2020 ... For Connecticopy Kent
    his error may have sent 110VAC to the DC controller (or whatever canon calls it) - a direct AC short to ground could not do such a thing and could not result in a phantom jam
    i would also check for any pinched harness cables relating to the egg-sit sensor - perhaps the fuser unit is pinching the harness
    from the service manual:
    14.15.7 Function test ((6) FUNCTION TEST)
    0011-0890 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i
    Press the numeric keypad key 6 on the test mode menu to select the function test.
    Press numeric keypad keys 1 and 3 to 9 during the function test to enter the menus listed below.
    T-14-28
    G3 signal transmission test (6-1: G3 480 bps Tx)
    Press numeric keypad key 1 on the FUNCTION TEST menu to select the G3 signal transmission test. This test transmits 4800-bps G3 signals from the telephone
    line connection terminal and speaker.
    Sensor test (6-3: SENSOR)
    This mode is used to verify the status of the unit sensors from LCD indications. Press numeric keypad key 3 on the FUNCTION TEST menu to select the sensor
    test. LCD indications change as the associated sensors turn on and off.
