iR adv c5235i
  • Will1
    • Mar 2013
    • 17
    [CQ] iR adv c5235i
    Morning All
    Please can someone assist. I have this machine that is not printing CYAN. We have tried a new dev tank, Dev drive motor, H.V PCB and drum unit. with the new Dev tank it ran for 2 days and emptied the Dev. Any information to this problem would be well received.
    Regards
    Will1
  • guitar9199
    • Sep 2016
    • 1099
    Re: iR adv c5235i
    If it's dumping developer after only 2 days, I'd suggest replacing the drum AND developer at the same time. How many clicks on the machine?
    • copier tech
      • 8106
      Re: iR adv c5235i
      Originally posted by Will1
      Morning All
      Regards
      Will1
      Are you running the machine on compatible toner?
      • MunsterTech
        • Sep 2014
        • 377
        Re: iR adv c5235i
        was it showing any signs of cyan at all before you changed all the parts or was it completely blank? Had one before where the laser shutter for cyan was not opening, the shutters are operated by a cam and the cam wasnt hitting the cyan shutter so it remained closed, if you take the side panel off the left hand side and pull out the process unit, you can see the shutters open/close if you operate the cam by hand.
        • Rachid.Akli
          • Oct 2011
          • 595
          Re: iR adv c5235i
          Morning All
          Regards
          Will1
          Hi,
          You may have an issue in the cyan toner supply system. The cyan toner can not reach the dev assembly. I suggest that you have a look on the cyan drum developing drive assembly. Replace the cyan toner supply clutch.
          Rachid.
          DRUM DEVELOPING DRIVE ASSEMBLY.pdf
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
