blur and bold
  • rvzanini
    • Jun 2016
    • 3
    [CQ] blur and bold
    IMG-20181218-WA0001.jpgi have a canon adv 6055 with a bold strip.l changed the belt,the cleaning blade,the bearings ,the transfer roller and the problem stand still.can anyone help me?thanks
  • roho
    • Mar 2009
    • 844
    Re: blur and bold
    Is the blur on the lead edge? Try both corona assemblies.
      • 23008
      Re: blur and bold
      It looks to me like a compression blur (crossfeed) caused by either the DF or something in the drum drive? Does that fit with what you know about this Canon?
        Re: blur and bold
        if he's using the DF.. does he get the same result from flat glass? that would rule out scanner bed and point to DF assmy No?
          • 23008
          Re: blur and bold
          Roger that. =^..^=
          • rvzanini
            • Jun 2016
            • 3
            Re: blur and bold
            changed coronas wires and cleaned up.still the same.
            Problem solved when l find a loose belt near from transfer belt gear.figure 330 item 72 XF2-1606-260 3 BELT, TIMING, COGGED.
            lI do not know how it happened, but the machine is used and I do not know the history.
            • allan
              RTFM!!
              • 5462
              Re: blur and bold
              Is this on every page or only the first print? Looks double sided does it only happen on the one side?
              Whatever
