Which SMB version support by Canon C5200 series.
  • copier tech
    • 8141
    #31
    Re: Which SMB version support by Canon C5200 series.
    Originally posted by tinalt
    Is there any chance you have the info for the C350 firmware?
    Use the CDS updater of if you want to install it via USB it drop us an email
    Firmware Update - Printer & Copier Firmware
    • Big Flo
      • Jun 2018
      • 15
      #32
      Originally posted by disamm
      This version can only doawnloaded directly on the device, go to the firmware update menu, select special version and type this values:
      Registration ID: 00006721
      Password: 43149128
      Does this ID and Password work on US Models?
      • lionex3d
        • Jun 2013
        • 41
        #33
        Originally posted by giogi
        The firmware can be downloaded from the CDS Server:
        iRAC 5051 v83.68
        Registration ID: 00006109
        Password: 50231700
        would this version support smb2 scanning?
        • techandtrader
          • Jun 2016
          • 330
          #34
          Originally posted by ReproKev
          That's what I thought.
          Do the new firmware versions for those machines automatically come with SMB 2/3 and it just needs to be enabled, or do I still need to download the "special" firmware that needs a code and password like mentioned a few posts above?
          Thats a good question. I think so but not sure.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            #35
            For the older machines that didn't support smb v2/3, the special firmware automatically turns on smb v2/3 and turns off smb v1. Note, once special firmware is installed you can not upgrade regular firmware anymore or it will revert back to smb v1.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
