ir 5oooi - printing smear..!
  • john_g_chua
    • Aug 2025
    my ir5000i whenever it runs copy, it always have a printing smear or should i describe it as a cloud like horizontal line. It only appears in one part and sometimes it appears sometimes it doesnt. the cloud line is irregular in shape and it varies in shape. how wil i remove it?
    I already cleaned the cleaning blade, I polished the drum, replaced all corona wires, drained the developer and clean them but still the cloud horizontal lines apears.. sometimes it doesnt..
  • smiley
    • Aug 2008
    • 615
    hi i have in counter this problem many times before its on developing unit maby one of your roler spacer stocks its bearing.or sometimes the adjustment of toner in developing unit is to high.
    there is no glory without sacrifice
    • SCREWTAPE
      • Aug 2025
      Did you replace? meaning.. Did you put brand new primary, pre-transfer and transfer separation coronas ass'y, what about potential control? Whats the meter count? Is this a network printer or is this happening off the glass? if so, check the optics, if they are dirty clean them.
        • 23010
        I'm a little unclear about the terminology. Is it a cloud or a line? Distinct or indistinct? Can you post a sample of the image quality problem? =^..^=
        • xtremejr
          Smear
          Try replacing the developer roller. It may be shorting to the drum.
          • Henry
            • Dec 2007
            • 18
            Try setting the fuzzy to 0 from service mode.
