IR Adv C3320 thick paper issue.
  • uclbph
    • Jul 2011
    • 34
    [Misc] IR Adv C3320 thick paper issue.
    hi,
    i have IR Adv C3320 copy & print issue on thick papers(170gsm -256gsm).
    the copy & printing on 80gsm copier paper is very good, but on Heavy 3 & Heavy 4 setting the quality degrade.
    attaching herewith the original file and printed on 256gsm paper image.
    kindly advice.
    Thanking
    uclbph
    • 8164
    Re: IR Adv C3320 thick paper issue.
    Originally posted by uclbph
    hi,
    kindly advice.
    Thanking
    uclbph
    What is the life of your fuser unit?
    • guitar9199
      • Sep 2016
      • 1100
      256 Gs/m is the max weight this unit can handle (Bypass tray only), so if you're getting poor fusing like that I'd look at the fuser unit. Estimated life on those units is around 180K pages. If you are near or over that, it's time for a new fuser unit.
      • uclbph
        • Jul 2011
        • 34
        print count 13000 prints only.
          • 8164
          Age comes into play on these old models.
          • Copylady72
            • Jul 2019
            • 35
            hi,
            kindly advice.
            Thanking
            uclbph
            Are you making sure that the media type is set to heavy paper on the printer? Just asking because it looks like what happens when the settings do not match the paper.
            Sent from my SM-N950U using Tapatalk
            • uclbph
              • Jul 2011
              • 34
              machine installed around dec 2016
              • uclbph
                • Jul 2011
                • 34
                when media set to heavy3 or heavy 4, this problem occur, otherwise copy& print on normal copier paper 80gsm is very good quality.
                • darkocg88
                  • Jan 2018
                  • 63
                  Just making sure you're using bypass tray?
                  Also, is it plain paper, glossy, etc?
                  If fuser isn't worn out, its paper settings issue.
                  Sent from my Moto E (4) Plus using Tapatalk
                  • Canuck
                    Tech Specialist
                    • 1713
                    Do full gradations on plain paper, then do full also for Heavy 3/4 with that media...Also now that I've looked at sample, it is a transfer issue. If paper is registered properly, etc,I would replace the external secondary roll on the door. Make sure its contacts are clean. Then itb would be next. Definitely a transfer issue
                    • uclbph
                      • Jul 2011
                      • 34
                      fuser unit isn't worn out. looking good & rotating smoothly.
                      what setting to be done on Heavy 3/4 paper ?
                      • uclbph
                        • Jul 2011
                        • 34
                        secondary transfer roller is clean, but how to ensure that during printing its contact are intact ?
                        • Canuck
                          Tech Specialist
                          • 1713
                          . Clean the metal contact that touches the shaft near the end and apply conductive grease. Did you do all the proper gradations as I suggested? Could be a bad HVT.. hard to say. Definitely a transfer issue
                          • Copylady72
                            • Jul 2019
                            • 35
                            I was looking at the media types on another device just for comparison. It shows that 256 gsm is considered Heavy 6. Do you have that option when running through the bypass? Heavy 4 only goes up to 180 gsm, for example.
                            • uclbph
                              • Jul 2011
                              • 34
                              i have Heavy 3 (160-220gsm) and Heavy 4 (220-256gsm) option showing in the control panel
                              when feeding through bypass.
                              there is not heavy 6 option.
