C5235A E602-0001
  • brob
    • May 2025
    C5235A E602-0001
    Hi
    I have a C5235A that now comes up with E602-0001 after a power failure. it shows a black screen and after a few minutes this error shows up. I did some reasearch and it seems like the hard drive is damaged. I have SST 4.74 but dont have the firmware for this printer to put onto a new hard drive. Could someone please send me the firmware so I can get my printer back running?
    Re: C5235A E602-0001
    Originally posted by brob
    Hi
    I have a C5235A that now comes up with E602-0001 after a power failure. it shows a black screen and after a few minutes this error shows up. I did some reasearch and it seems like the hard drive is damaged. I have SST 4.74 but dont have the firmware for this printer to put onto a new hard drive. Could someone please send me the firmware so I can get my printer back running? Thanks
    are you a tech with SST and SM?
    • jio9000
      • Mar 2020
      • 26
      i am a computer tech , i have one of those c5235a with the same issue , will purchase firmware if i have to , can any one assist me ?
        • 8104
        Most likely your HDD needs replacing but its worth reloading the firmware if that fails you'll need to replace the HDD & reload the firmware.
        Make sure you buy the correct hard drive you cant just fit any HDD.
        Drop us an email if you need the firmware.
        Firmware Update - Printer & Copier Firmware
        • jio9000
          • Mar 2020
          • 26
          i just bght the firmware from the proposed link ,with usb inserted , i only see the option to format drive (option 4) , when selected it says, ( formating HDD ALL ERROR the machine seems to be locking all drives they are inserted with a password , so im currently stuck
          someone please help
            • 8104
            someone please help
            You need to replace the HDD with one approved from Canon.
            Measures against E602 error occurence.pdfMeasures against E602 error occurence.pdf
            • jio9000
              • Mar 2020
              • 26
              WhatsApp Image 2020-07-03 at 3.29.39 PM (2) (1).jpgWhatsApp Image 2020-07-03 at 3.29.39 PM (3).jpg
              [ATTACH=CONFIG]46089[/ATTACH][ATTACH=CONFIG]46089[/ATTACH]
              greetings from the island and .thanks for your reply , for the c5235A initially i changed pcb 1 as the hdmi port for the panel was damaged ( on changing it i on booting up i kept receiving the Error Code E355-004
              , i then realized that (pcb 1 serial number fm0-0311-xxx(001) was the original board i took out and not (fm0-0311-xxx). after removing (fm0-0311-xxx) i then proceeded to source fm0-0311-xxx(001) and installed it. this was when i began getting the E602-0001 error and reduced options in download mode (is it possible that there may be an issue with the riser pcb or pcb 2 , thats causing an issue with the copier processing information communicating with the hard drive , because i tried a supposingly working hard drive from the same model , same issue (note. the box checker tool is also no longer accessible as it was b4 i made the switch. . (fm0-0311-xxx) is now also giving me the e602-0001 no longer gives me e355-004 error as the machine dosed not reach that far
              • jio9000
                • Mar 2020
                • 26
                [ATTACH=CONFIG]46102[/ATTACH][ATTACH=CONFIG]46103[/ATTACH]
                SramImg.bin
                keeps failing whether i am trying to upload or download ,in download mode
                • giogi
                  Engineer senior
                  • Jan 2016
                  • 182
                  "Knowledge is a source, but unfortunately ignorance is a sea."
                  • jio9000
                    • Mar 2020
                    • 26
                    after installing the correct pcb 1 , i began getting error code E602-0001 , i noticed there seems to be an error or fail every time i attempt to back up or download data via sst or usb in download mode. could it be that there is an sdram issue on pcb 2 ????? , as ive tested a working hard drive and got the same issue .
                    also the options in download mode are limited , see pics
                    WhatsApp Image 2020-07-03 at 3.29.39 PM (4).jpgWhatsApp Image 2020-07-07 at 9.13.56 AM.jpg
                    • giogi
                      Engineer senior
                      • Jan 2016
                      • 182
                      to extend the menu, you have to insert a USB key with firmware loaded.
                      after you will see many options
                      next step, you have to format the new HDD and load firmware (overwrite)mode
                      • jio9000
                        • Mar 2020
                        • 26
                        i did that , download moad only chanegd from (HDD) to (USB) with limted options , i get error when i try to to formatt all , and error when i try to back up sdram
